Author Topic: Dual Cases with a forward shift rear case?  (Read 3181 times)
Evilwhitey
  • Turtle Points: -1
  • Member since Apr '06
« on: Aug 24, 2006, 08:36:40 AM »
I picked up a 4.7 marlin case six months ago for my 93' 4cyl pickup and it's worked perfect! Thanks Marlin. Now I want to run a doubler infront of my 4.7 case. Can I do it using my forward shift case? Thanks!
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Member since Feb '05
  • Full Trucker Effect
Re: Dual Cases with a forward shift rear case?
« Reply #1 on: Aug 24, 2006, 08:59:47 AM »
You cannot use a forward shift case in the rear but you can use it for the crawler box.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Aug 24, 2006, 09:13:05 AM »
yea,  you can get a topshift crawl box from Marlin already clearanced for the 4.7 gears  and swap the 4.7's to that box and use the crawler portion of your forward shift  between the tranny and the topshift
or just run the 4.7 in the front case :yikes:
Evilwhitey [OP]
  • Turtle Points: -1
« Reply #3 on: Aug 24, 2006, 09:15:32 AM »
Ok, so correct me if I'm wrong but I need to find a top shift t-case to throw my crawl box on and then I can put a doubler infront of that? What does that all entail? Is it very difficult? Thanks for your help!
Evilwhitey [OP]
  • Turtle Points: -1
« Reply #4 on: Aug 24, 2006, 09:36:30 AM »
I just saw that marlin has a top shift conversion kit. If I use that kit can I then bolt up a doubler in front of that?
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
« Reply #5 on: Aug 24, 2006, 09:55:53 AM »
It goes the crawler box, adapter, then the transfercase.  It sounds like you probably shouldn't try doing this.  The best advice I can give you is to buy all of the necessary parts and have Marlin assemble them. :greengrin:
854RUN
  • Turtle Points: 30
  • Male Posts: 890
  • Member since Mar '06
  • 4WHEEL 4EVER
« Reply #6 on: Aug 24, 2006, 10:16:35 AM »
OK, do you have a Donner case for the front box yet if not get one with a top shift and What you can do is use the forward shift rails, forks, and stuff on the first box. So you need to get a case that is a top shift and take it apart. #1 Take the shifter, shift forks, and shift rails out of your Donner Case #2 tack your case with the 4.7 gears and open it up. Pull the forks, rails, shifter and put it in the front case then take the top shift stuff and put in in your full t-case. bolt it all together, bolt it to the tranny cut a hole in the floor for the shifter and shorten the rear driveshaft and lengthen the front, oil and you are crawling.  :biggthumpup: on the tech page on the web store there is a good right up on tacking your t-case apart if you are not to comfortable and it has good pics with it on every step :   http://www.marlincrawler.com/htm/transfercase/crawler_installer/crawler_inst.htm  http://www.marlincrawler.com/docs/470install/installation.htm
hope that help and not confuses :headscratch:
-JOSH-
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #7 on: Aug 24, 2006, 10:35:57 AM »
The only way to run a forward shift transfercase in a dualcase setup, would be to run the MC01 or MC03 dualcase adapters, both of which were discontinued in 1995.
I just ran out back to our Trophy room and took some pictures of a prehistoric MC01 twp piece adapter. Take a look at these relics:
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #8 on: Aug 24, 2006, 10:41:07 AM »
Wow those are old! Doesn't look like they came from no trophy room.
  • Administrator
  • 511:1 Club
« Reply #9 on: Aug 24, 2006, 10:50:35 AM »
That MC01 adapter was 12 inches long and accepted either a top or forward shifting t/case behind it.
But as soon as Marlin wanted to run Triple Cases, he knew he had a problem, so he redesigned it to the MC03, which was about 9 inches long, and then the MC05, which is just 6.5 inches long.
So today, because we want to make these dualcases as short as possible, we require the rear transfercase to be top shifting only.
I recommend you convert your 4.70:1 case to a top shift and run that behind the MC07/08 adapter.
Please, whatever you do, do not use the 4.70:1 gears in the Crawl Box unless you are using a 23-spline rear transfercase.
Last post Oct 02, 2005, 10:55:14 PM
by Hyena
Last post Jan 23, 2007, 01:25:14 PM
by Boheefus
Last post Feb 09, 2007, 03:49:42 PM
by Lowgear
Last post Nov 07, 2008, 11:37:37 AM
by 85 SA TOY
Last post Nov 16, 2008, 11:52:24 AM
by Blue1982
