Well I'm not sure if its internal or externaly regulated. I'm thinking its internal because I don't see a regulator anywhere. I"ll try and clean the terminals a little better and see if that helps. What sensor are you talking about Jim?
I've got the same problem on my 80. Charge light is on, new regulator, alt and battery. With it running I've only got 12.3 volts at the battery. Still haven't figured out the problem. Sorry to hijack.
Started by Ruari General 4WD Discussion
Started by blyota91 General 4WD Discussion
Started by YOguyDa General 4WD Discussion
Started by Yota85 Toyota Pickup/4Runner Tech 1979-95
Started by mudweiser Toyota Pickup/4Runner Tech 1979-95
