Charge And Brake Light
Started by Ruari, July 16, 2003, 08:51:48 AM
Ruari
My charge and brake lights came on Monday morning of last week.  My voltage gauge still showed some charging was going on.  I had the battery tested and it is good.  I had the voltage regulator tested and it also is good.  I had the alternator tested and it showed no output.  Yet my gauge showed otherwise.  I have replaced the alternator with a new one from Auto Zone.  Now it is not charging at all.  What is next?
Any suggestions?
Ruari Legg
'84 X-TRA cab, 5.29 Front F-J80 high pinion e-locker/5.29 rear Tacoma e-locker, R.O.R.E. e-locker skid plates, MC dual t-case #480, MC 4.70 gears #1755, Budbuilt crossmember, MC crossover steering, Howe hydro-assist steering, Alcan springs with Orbit Eyes, FRORF full floater, TRD cam, LC Engineering adjustable cam gear, distributer, solid steel engine mounts, longfields, 35"x13.5 BFG Krawlers.
krawlr
I would start with fuses, look for a "charge" fuse under the hood, and a "gauge" fuse under the dash.
27-AT, some other adapter, flipped D300, twin sticks on cables.
[shamelessplug] www.krawlr.com [/shamelessplug]
Don
Yes, check the fuses before going any futhure
Ruari
Thank you for the sugeestion.
Fuses have now been checked and are all good.  My next thought is a bad wire somewhere or loose connection.  Any other suggestions?
Ruari Legg
mr4x42u
have the new alt tested..I think auto zone sells junk..but thats just my .02     when it come to stuff like startes,alt or electrical items I will only get a napa or dealy item..seems i have the best luck there over any of the others..I have gootn new alts that were no good..dropped during transport and broke the brushes or broke the brushes while it was going back together..what year is your rig?I know some rigs have a charge lamp relay under the driver side of the dash,,or pass side depending on the year..but if its bad find a used one..A new one fom the dealer is over 100bucks..I think close to 150. :yipes:
Ruari
Ruari Legg
mr4x42u
#6
I think the 84 still had it..1st have you new alt checked..can you drive it down to napa?They or most parts stores can check it at idle and under load for amprage..Or do you have a volt/amp meter to check output to see for sure..I guess If i read your sig I would have known that it was an 84.. :smack:
That relay I think is on the driver side of that rig...I think..The only other time I had that problem with that realy was in an 82 and a 83..like I said..toyota wants over 100$new.. :yipes:
#7
Quote from: mr4x42u on July 17, 2003, 03:28:40 AM
Hey man, use the smiley -  :twocents: - that's what its there for
Rore
The great thing about Toyota is that they really spent alot of time making their wiring system very reliable. If you've ever torn into a wiring loom, you'll know what I mean. But the bad thing is that Toyota made their wiring system very reliable. So when something goes bad, like a shorted wire, good luck finding it. Use an audible single meter to see if you've got any wire that is not Brown or White/black-stripped being grounded out. Just hit a main loom artery and start probing around. You'll need a couple of these though  :beer: :beer:
Ruari
#8
I probably won't make it to the auto parts store but I do have a volt meter.  What should the output be on that alt?  14-18 volts?
I was going to mention the sig. but I do own 2 Toys... although they are both '84 x-tra cabs.
:smack:
Ruari Legg
Ruari
I totaly agree with you Big Mike.  I just hope it is not a ground problem or it will be more than 2 beers.
Ruari Legg
84runner
well it seems like u got enough to check for the charge light, now what about your break light is it still on?  If so Check your break fluid first then your E-brake switch.  And Auto Zone alts are junk
Ruari
I know that the brake light always comes on when there is a problem with the Alt, Regulator, or Battery.  As soon as I fix the electrical problem it will go out with the charge light.
It sounds like the consesus is that I should not have gone to Auto Zone for the new Alt.  I normally do not go there, but since the guy at Kragen looked at the corosion on my battery and said it needed to be replaced and that he wouldn't even test it, that was the only other option at the time.  I will get a new Alt and see if that fixes it.  If not then I will attack the wiring loom and the box that may or may not be in the kick panel.
Thanks for all the input.
Ruari
Ruari Legg
mr4x42u
Quote from: BigMike on July 17, 2003, 11:16:11 AM
Rore
Its rare to see such a problem deep inside a toy wire loom..If its not the common thing,,connector at the battery,,crap in the fuse panel under the hood or a commector or plug at the alt,,I'd go with a bad alt or relay.. :twocents: :twocents: :twocents: :twocents: :twocents: :twocents: :twocents: :twocents: :twocents: :twocents: :twocents:
Ruari
#14
O.K. the verdict is in.
DON'T BUY ALTERNATORS FROM AUTO ZONE!
I bought an Alt. last night from Napa, a long drive from my house, and got it in..........
I am charging 100% again. :shocking:
:beer: :beer: :beerchug: :beer: :beer:
Thank you to everyone for their excelent input and  :twocents:.
Ruari Legg
mr4x42u
I think not only autozone but checker,,shucks,,kragen,,mom and pop what ever..I think they all suck..I just trust them more..when it comes to eletrical items napa or dealer all the way...
  :twocents:
krawlr
Quote from: mr4x42u on July 18, 2003, 07:12:43 AM
  :twocents:
I'll second that, "white box" alternators have caused me a few headaches. :hammer:
Don
95TacoTruck
Kragens, pep-boys and auto zone are all crap for electrical parts.  Go with napa if you are going to but at a local parts store.
95 Tacoma Extra cab, many mods to come........
red85
I had a chevy diesel once that ate starters weekly. after going the kragen route for a couple months I started marking them before returning them. they tried to give me the same starter 3 different times. I finally got a cash refund and went to napa and paid $65 more for the starter there. The first one lasted 2 months, longer than any other so far. I took it back to get it replaced and they tried to give me one of the ones I had marked from kragen! They all get their crap from the same places from what I saw!
The best bet is to take your electrical components to an auto electric shop and let them reman yours! I have had alot better luck doing that!
Also so not to be off topic, I was having about this same problem and just went and found that I have a bad fuse! now I need to go get a replacement! and an extra!
skunkyoda
I have been having charging problems and electrical issues for a few weeks now. It started out as a bad alternator (brake light and charge light on at the same time time). So I replaced my alternator (with a used toyota alternator from toyota dismantlers in SAN JO) then my truck had new symptoms so I changed my
battery terminals
wiring from battery to starter celenoid
wiring from battery to glow amps fuse
checked all my grounds
so today my 3 week old used alternator went out.
thats where I am @ right now. I just read all and I mean all the forums on electrical issues similar to mine and about charging issues and about alternators, I read about everything.
My next move is a reman alternator from toyota for $100 something ( I forgot the total price). according to everything I read that should take care of everything.
I will also be paying to get my belts done cause I need it. Dont want to do it myself, pain in my arse. I think my belts and the new alternator should take care of my problems after I have done what I have done.
Excuse me for bringing back this old ass thread
thanks
:crazy:
1985 22RE EFI YOTA 4RUNNER, 31's, Open Diff's
Everybody knows there ain't no such thing as Leftover Crack
PLEASE GOD PROTECT ME FROM YOUR FOLLOWERS!!!!!!!
BCD
In my experience the charge and brake light symptoms are relieved quite easily with a toyota reman alternator, none others (who knows what condition the brushes in a used are in) :twocents:
skunkyoda
BCD I I agree with what you said. I have read about 10 others on this board say the same exact thing.
So today, I was going to go get my reman'd alternator from Toyota I looked up 4 that are somewhat close made a few calls.
I found out about the alternator I want for my 85 EFI 4runner 5speed,  is a 60 amp with an internal regulator, I also found out that they want $193.84 not including tax, wich throws the total aver $200. That is alot of money.
They know I dont have a choice.
I guess I gotta do what I gotta do.
:dunno:     :crazy:
reklund5
Quote from: BCD on February 23, 2006, 09:40:05 PM
I taught you right, boy!!  DEALER PARTS ONLY!!!!  When you wanna put in that oil seal?
Ryan
skunkyoda
I went to different toyota dealer today. They want to sell an alternator for my 854runner to me for $260 not including tax.
I cant freekin believe this shite!!
reklund5
$260- is that NEW or REMAN?  You CAN get a Toyota reman alternator, by the way.   Many dealers only sell new, but can order remans.  Either way, $260 isn't that bad considering it'll probably last 200,000 miles and you'll only have to put it in once.  Try that with any part from Autozone...
If you still have the original Toyota alternator for your truck...you can just replace the brushes if that's all thats bad.  The dealer can get you those too.  It'll require a little soldering, but works like new if you do it right.
Ryan
skunkyoda
I got a remand alternator from Toyota of Redwood City, and I just installed it.
Only cost $193!!
So I'm stoked
:crazy:
BCD
Ryan
Maybe next weekend...do you have saturday or monday off?
reklund5
Quote from: BCD on February 26, 2006, 07:00:42 PM
Ryan
Both...it's my 3-day.  I'm planning on bending some tube for the pickup too...
FYI on re-manufactured alt., starters and the like, when I lived in Hesperia my next-door neighbor rebuilt them for a living OUT OF HIS GARAGE. Even though they are boxed like it's a big deal operation he did rebuilds for all the "Brand Name" companies and boxed them in their boxes. Only the worn parts are replaced and that's what they consider being rebuilt. Usually bearings and brushes are replaced and that's it. Then they make the case all pretty and new looking and off it goes. If the diodes and internal voltage regulator is OK when it comes in they don't replace them.
I went through a few alternators in my Maxima years ago and finally decided to buy a Nissan re-manufactured alt. Never had anymore trouble. I am in the buy it from the dealer corner even if it is a re manufactured product from that day on.
:twocents:        :twocents:        :twocents:        :twocents:        :wave:
