Author Topic: R150 & ATF??  (Read 1236 times)
toysfreak
  • Turtle Points: 227
  • Male Posts: 632
  • Member since Sep '03
  • I Love My Marlin Crawler!
R150 & ATF??
« on: Aug 13, 2021, 07:33:46 PM »
Anyone ever use ATF in their manual trans?  Scored a 93 R150 and was filled with automatic transmission fluid.  I didn't know it when I scored it, and seller never mentioned anything.
Hesitant on installing this trans in my rock crawler,  cause this trans has a perfect input shaft,  where it goes into the pilot bearing  makes me wanta run it.  My v6 trans has a worn end/input shaft
95 4 runner. 4 cyl dual ultimate w. R150.  V6 rear w spool.  New Chevy springs on 12" extended frame.      Front.  SAS w chromoly shafts.  And spartan    In frazier park ca 93225
Gnarly4X
  • Turtle Points: 5134
  • Male Posts: 4,254
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
Re: R150 & ATF??
« Reply #1 on: Aug 14, 2021, 04:16:42 AM »
Hey toy....
Good question.
Answer:  Automatic Transmission Fluid is spec'd for several manual transmissions - Ford, Mazda Mitsubishi, etc.
How good is ATF?  Some auto manufacturers don't recommend changing fluid before 100,000 miles!!
ATF has a viscosity of about 5w-20.  I could see someone running ATF in a manual tranny in a rockcrawler where the climate is extremely cold.
ATF is formulated for lubrication, but also for heat absorption.  Manual transmissions don't generate as much heat as automatic trannys.
ATF acts as a good detergent.  If you picked up an older manual tranny and wanted "clean" the inside, you could fill with ATF, drive it for 100 miles, and drain it and see how much residue or metal was in the transmission.
In my early 1982 Mercedes diesel, I used to put in a quart of ATF in a full tank of fuel about every 4 fill ups for many years.  It cleaned the cylinder and combustion chambers really well.
While I was breaking in my newly rebuild W-56 I used Castrol 10-40 motor oil, recommended by the shop that rebuilt it.  Then filled with Redline MTL.
In my VW transaxle on my 3 sandrails, I used 20-50 motor oil, rather than gear oil.
I'd be using whatever is spec'd for that transmission and running Redline or Mobil 1 Synthetic.  I would not hesitate to install that tranny unless there are known quality issues.
Gnarls. :usa:
« Last Edit: Feb 20, 2022, 12:08:19 PM by Gnarly4X »
cavey
  • Turtle Points: 496
  • Male Posts: 90
  • Member since Oct '03
Re: R150 & ATF??
« Reply #2 on: Aug 18, 2021, 01:52:09 AM »
down here in australia the toyota corolla always  had shifting issues ie crunching the gears and the only way they could stop it was by running ATF  ,my first RN46 hilux was the same so for a while I ran ATF in the tranny with no problems
own a 1989  LN106r diesel with a 1KZ-T 3 litre turbo diesel  bolted to a imported R151F gearbox with snorkel Rancho springs & shocks & Detroit lockers F & R & 11x 32  cooper sst ultimate dual transfer cases 130 litre fuel tank   full floating disc brake rear end
LittleSteve
  • Turtle Points: 170
  • Male Posts: 943
  • Member since Jan '14
  • What is this Toyota you speak of?
Re: R150 & ATF??
« Reply #3 on: Feb 20, 2022, 10:23:33 AM »
Are you sure it's ATF and not synthetic MTF?
They are often dyed red.
Refusing to fit in or comply.
Easy is not worth anything.
cavey
  • Male Posts: 90
Re: R150 & ATF??
« Reply #4 on: Mar 29, 2022, 12:57:21 AM »
it was ATF because back then in 1984/5 synthetic oil was rare
LittleSteve
  • Male Posts: 943
Re: R150 & ATF??
« Reply #5 on: Mar 30, 2022, 12:24:38 AM »
I mean was it ATF in his trans not the stuff you put in lol
cavey
  • Male Posts: 90
Re: R150 & ATF??
« Reply #6 on: May 04, 2022, 12:28:45 AM »
It was Dextron ATF
Last post Jul 07, 2004, 05:19:59 PM
by brainlessfool
Last post Jun 18, 2010, 01:24:01 PM
by dntsdad
Last post Jan 27, 2011, 09:57:54 AM
by Burl
Last post Dec 06, 2017, 07:35:40 PM
by cporche
Last post Aug 02, 2020, 02:40:01 PM
by Chuck78
