Author Topic: Strange Noises  (Read 2157 times)
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: Strange Noises
« on: Sep 01, 2004, 10:00:52 PM »
This could be a normal internal noise from the power steering pump when the wheels are pegged and the box has bottomed out.
When this happens, instead of blowing the high pressure hose, the spinning rotor housing which containes the veins, will push against a large coil spring and the excess pressure will vent around the rotor housing.
This is the cause of the internal high pitch sound.
Marlin
Last post May 14, 2006, 08:13:20 PM
by Lonestar Honcho
Last post Aug 14, 2007, 08:53:02 PM
by YotaJoe
Last post Aug 23, 2009, 11:23:08 PM
by TacoCrawler
Last post Apr 19, 2013, 02:20:41 PM
by amm9130
Last post Feb 06, 2020, 05:30:30 PM
by onwheels
