Author Topic: Starting issues  (Read 1735 times)
highridin4x4
  • Male Posts: 237
  • Member since Oct '06
Re: Starting issues
« on: Jun 16, 2007, 07:55:12 PM »
Is it a good load click or a click click click. if its a good load click I would check your solinoid contacts inside the starter. It sounds like the plunger is kicking the drive out but not making conection between the battery cable post and the starter cable post. You can put a test light on the starter cable post and try to start it if it lights up your starter is bad if it does not its your solinoid contacts. I have seen one starter that the drive gear teeth did not mesh perfectly with the ring gear when kicked out so the plunger could not make contact (the drive gear tooth would hit the ring gear tooth and not mesh with one another but if it meshed it was fine). If its a click click click could be a ground problem how is the small ground wire going to the relay box next to the battery?
Scott
Last post Jun 06, 2005, 09:48:46 PM
by Truggy
Last post Oct 31, 2005, 06:15:18 PM
by *FFC*
Last post Feb 14, 2009, 12:57:08 AM
by Jordan7118
Last post Oct 02, 2011, 12:09:13 AM
by locked 4x4
Last post Oct 20, 2011, 03:30:56 PM
by superyota
