Author Topic: What caused this to happen to my header???  (Read 3925 times)
4xtoy
  • Turtle Points: 151
  • Member since Nov '05
Re: What caused this to happen to my header???
« on: Jul 08, 2006, 04:53:59 PM »
The plate you have here for protection is really hampering the ability of the system to move when the engine flexes on the mount or the frame flexes during articulation, might wanna try and loosen it up a bit?
edit: The way yours cracked, I would bet that this section failed to let the system move and it was engine movement (torqueing) that actually caused the crack.  The flex joint between the cat and header would solve this problem.
Acctually it has 3/4" of clearance on every side of it. The plate is only there for structure rigidity since I cut out a huge chunk of a primary cross member.
Quote
you need to un weld it at the end of the header  befor the cat,  i use a extended slip joint, plenty tight with minimal leak,  but allows the engine flex  and keeps the pipe from causing twisting force on the header
The header has a ball flange that I guess I could loosen a bit. I like the idea of the flex joint though.
Quote
Factory down tube had a clamp at the bellhousing to stabilize the header.  Do you still have this?  If not, try it.
Don't have it. How would it adapt to an aftermarket header.
Last post Oct 02, 2002, 11:57:13 AM
by SeaBass44
Last post Dec 13, 2004, 07:10:47 PM
by guywithuglyyota
Last post Apr 22, 2007, 01:43:09 AM
by topar
Last post Jul 24, 2008, 08:39:22 PM
by Stocker
Last post Dec 05, 2009, 03:13:17 PM
by emsvitil
