Author Topic: 2000 Tacoma V6 - Lifts kits what IS the best and what is just ok ?  (Read 2605 times)
HOODLUM
  • Turtle Points: 11
  • Male Posts: 81
  • Member since Mar '05
  • Wrecking Crew
    • rightcoast4x4.com
The OME is rpobably the better of them. They are expensive but you get a nice ride while lifting your rig as well. The only other company I've used for newer trucks is Cornfed suspensions Dave uses a sold billet spacer that has a inner lip that sits inside the coil to prevent pop-out.They use an Add-a-leaf for the rear and you can upgrade the shocks to Bilstiens as well. The only other advise I can give you right now is if you lift your taco more than 2" get the front diff drop spacer kit it will help out a lot when re-doing the alignment.
99 TACO 2.7 4CYL  HP d-60 front d-70 rear 5:13's and detroits 63" chevy rear springs second gen rears up front.
http://rightcoast4x4.com/
Last post Jan 14, 2005, 04:42:06 PM
by Krob
Last post Jan 02, 2013, 12:42:45 AM
by Rocksurfer
Last post Mar 07, 2007, 11:27:35 AM
by Thumper
Last post Dec 25, 2005, 01:04:58 AM
by BLACKDOG
Last post Apr 24, 2006, 07:27:27 PM
by Rockdiver
