Author Topic: Turbo mounting options.  (Read 1666 times)
88sasturbotoy
  • Turtle Points: 2
  • Male Posts: 108
  • Member since May '13
  • if it aint broke....add some rowdy to the mix
Re: Turbo mounting options.
« on: May 28, 2013, 12:00:38 AM »
Placement of the turbo doesn't matter that true just for looks....steeds manifold puts the turbo flipped up which requires a little tinkering to get it all to fit....lc engineerings  mani keeps it down which is what iI prefer I own a r te I've got a garret t3 tec turbo with internal wwaste gate do in between.  15 and 18psi the intercooler is def a way to go but like stated really only needed if runninI 8 or more psi anything over that the motor will get hot your mani will crack and cause havoc....as for tToyota doesn't make parts they do cause I often hit up my Toyota dealer for small items just very expensive like said before WWW.22rte-trucks.com is where u wanna go for any questions you have anything u need an answer to will be answered there
88 xtra cab pickup solid axle swapped 5spd swapped 4.7 swap turbo 15psi swapped = rowdy
Last post Sep 17, 2004, 08:07:43 PM
by kyle_22r
Last post May 29, 2005, 11:26:37 PM
by WHITE_TRASH
Last post Aug 19, 2005, 10:45:58 PM
by 88-REDRYDER
Last post Apr 03, 2008, 04:57:20 PM
by 82rustbeast
Last post Jul 28, 2011, 07:24:33 AM
by SierraDave
