Author Topic: 85 4runner and the work never ends....  (Read 120196 times)
Jordan7118
  • Turtle Points: -21
  • Male Posts: 1,105
  • Member since May '07
Re: Back from the shop, 85 4runner build
« Reply #90 on: Dec 02, 2008, 07:08:15 PM »
 Front springs are not long enough to go further forward.
Maybe it's a bad picture, but it looks like the shackle angle is almost at a 45 degree rearward sweep. This means that you could've thrown the spring hanger further forward. Picture could be weird. Not knockin' your work, though. Good work on everything else!
GJToyotabug
  • Male Posts: 969
  • Member since Jan '08
  • The bug is deep in this one
    • Alcan Spring
« Reply #91 on: Dec 02, 2008, 07:13:38 PM »
i think that its gonna rub. and the shackles will probably hit the body mount, might want to look into some  :banana: shackles from sky's
John Doe [OP]
  • Turtle Points: 469
  • Male Posts: 1,586
  • Member since Jun '05
    • Bored In Iraq.
« Reply #92 on: Dec 02, 2008, 07:46:50 PM »
Before I left the shop we pulled out the fort lift and there is some rubbing at full flex, and the shackles do hit the body mount. I might just shave the body mount a little to take care of the interference.
eMOJO
  • Turtle Points: 2
  • Male Posts: 82
  • Member since Dec '08
  • SAS my ride... please
« Reply #93 on: Dec 03, 2008, 01:20:30 AM »
The build is looking great... more pics though  :greengrin:
If you can't see the bright side of life...
POLISH THE DARKSIDE :ninja:
4ROCs Offroad + Adventure
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #94 on: Dec 03, 2008, 08:25:29 AM »
Looking good.  you'll figure out the little issues.  :thumbs:
I like to Drive!
1981_toy
  • Turtle Points: -7
  • Male Posts: 657
  • Member since Nov '07
« Reply #95 on: Dec 03, 2008, 09:51:53 AM »
looks good!!! Good Luck and Thank you for serving the country!!
John Doe [OP]
  • Male Posts: 1,586
    • Bored In Iraq.
« Reply #96 on: Dec 10, 2008, 10:05:28 PM »
Well my leg is doing better and I have gone out around the block not much more then 2 miles twice. The ride is good, steering is straight, nothing to really complain about. Today I swapped in a sr5 cluster and wired up my E-lockers using 12Volt guy Harnesses and Switch panel. The panel is clean and good quality, the harnesses were Very well labeled. I highly suggest 12Voly guy for all your electrical needs!
Sadly I didnt take many pictures but I did take a few and will get them up tomorrow. Hopefully I will find some dirt and rocks locally I can go crawl and climb on with in this next week or so. If any one has any suggestions for any place even if its real simple let me know. Needs to be near to Sac/ Roseville.
John Doe [OP]
  • Male Posts: 1,586
    • Bored In Iraq.
« Reply #97 on: Dec 11, 2008, 07:22:58 PM »
Just a curiosity, You guys think I'll be good enough with out Longs in the front with my e-locker as long as I dont beat on it? I doubt I will see much time in or on rocks for many months, in a month I am shipping it out to Louisiana :( where I expect to be for nearly a year probably.  :rivers:
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,413
  • Member since Oct '04
  • Proud Parent
« Reply #98 on: Dec 11, 2008, 07:30:26 PM »
lookin' good. what spring combo you running again?
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,839
  • Member since Dec '05
  • California livin'
« Reply #99 on: Dec 11, 2008, 07:37:24 PM »
Dont hammer down while at full steering lock or in a bind and you will be fine.
John Doe [OP]
  • Male Posts: 1,586
    • Bored In Iraq.
« Reply #100 on: Dec 11, 2008, 07:44:53 PM »
The work form yesterday....
Thanks fortysixandtwo
3" allpro fronts and 4" marlin rears
I will try and get a pic on some level ground this weekend it does sit pretty level. I found the 3" fronts used but still in real good condition.
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,839
  • California livin'
« Reply #101 on: Dec 12, 2008, 06:58:37 PM »
Nice! Is that a 12voltguy panel? Looks sweet.
John Doe [OP]
  • Male Posts: 1,586
    • Bored In Iraq.
« Reply #102 on: Dec 12, 2008, 10:12:08 PM »
Today I wired up my E-lockers using 12Volt guy Harnesses and Switch panel. The panel is clean and good quality, the harnesses were Very well labeled. I highly suggest 12Voly guy for all your electrical needs!
That is correct.
SR5Yota
  • Male Posts: 163
  • Member since Dec '07
  • Is it wheelin time?
    • My SR5 Runner Build Up!
« Reply #103 on: Dec 13, 2008, 09:17:15 AM »
looks like your going to fire rockets with those switchs! :pimp:
DaveZ
  • Turtle Points: 4
  • Member since Jan '06
« Reply #104 on: Dec 14, 2008, 09:11:32 AM »
Looks good, I wheeled many years with stock birfs. You will be fine fine, when you start breaking birfs then buy some Long's.
Diamond Springs, ca 95619  530-622-2148 Dave
82 w/a 44 and a 60
http://www.davezoffroadperformance.com/store/
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • Member since Oct '07
  • low n slow
« Reply #105 on: Dec 16, 2008, 08:05:26 AM »
i ran 37's open in the front for a year and never broke a birf.
LilChief87
  • Turtle Points: -1
  • Male Posts: 917
  • Member since Jul '08
  • When in doubt Romp it out
« Reply #106 on: Dec 16, 2008, 09:40:41 AM »
yeah ive been wheelin stock axles too for the past 2 or 3 years open open f/r with 33s and 35s and never had problem know on wood  :hammerhead: and i took that truck through hell and back
John Doe [OP]
  • Male Posts: 1,586
    • Bored In Iraq.
« Reply #107 on: Dec 17, 2008, 11:33:43 AM »
Well after pacing another car at different speeds, it appears that the 5.29 gears and 35's are a good match, I am about +/- 6 mph over. If all goes well I will be going to Prairie City on Saturday morning for a few hrs to get some time to play before I head back to the swamp next week.
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,839
  • California livin'
« Reply #108 on: Dec 17, 2008, 11:49:44 AM »
Yeah my speedo is pretty close with the 5.29s/35s.
ROCKO
  • Turtle Points: -49
  • Male Posts: 743
  • Member since Sep '07
  • NOR-CAL WHEELIN
« Reply #109 on: Dec 17, 2008, 11:54:03 AM »
thats about right around 5 mph off same as mine with 529's and 35's
if you get board at praire city head up hwy 50 a little bit past placevill to sly park rd for some snow wheelin' i will be up there all day saturday.... :beer:
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
John Doe [OP]
  • Male Posts: 1,586
    • Bored In Iraq.
« Reply #110 on: Dec 19, 2008, 05:19:47 PM »
Well in continuing my efforts to keep my Runner unique I descided to not get some of the many mass produced round tube sliders.
They are a little shorter then I had wanted and could stick out just a little more but regardless they turned out great! They are strong as Hell and will be able to take anything I throw at them. Anyone in the Sacramento are that needs some help with some fab work I highly suggest Phil at Sillyneck Fab!
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,839
  • California livin'
Re: New Sliders, 85 4runner build
« Reply #111 on: Dec 19, 2008, 05:49:46 PM »
Those look sweet. Phil is a good guy and one hell of a fabricator he did a ton of work on my friend's CJ.
John Doe [OP]
  • Male Posts: 1,586
    • Bored In Iraq.
« Reply #112 on: Dec 19, 2008, 05:51:03 PM »
1 more pic, taken when I picked up the Runner
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,395
  • Member since Oct '06
  • proud parent!!!
« Reply #113 on: Dec 19, 2008, 06:24:45 PM »
that is a sweet runner, I like the sliders!
1981_toy
  • Turtle Points: -7
  • Male Posts: 657
« Reply #114 on: Dec 19, 2008, 06:42:16 PM »
i love the sliders i have square bumpers so i have to go with square sliders...b
blackSR5
  • Male Posts: 96
« Reply #115 on: Dec 23, 2008, 10:43:15 AM »
Truck looks awesome...You take it out on the trail yet????
Want a Runner or a truck...and a DIRT BIKE!!!
John Doe [OP]
  • Male Posts: 1,586
    • Bored In Iraq.
« Reply #116 on: Dec 23, 2008, 11:07:04 AM »
Nope  :rivers:
I just got back to my base in Louisiana. Wanted to go to Prairie city this past Sat, but needed to pack. Will be getting the Runner shipped out here by the end on Jan.
blackSR5
  • Male Posts: 96
« Reply #117 on: Dec 23, 2008, 11:23:17 AM »
That sux. I beat that you cant wait to wheel the hell out of that thing.
John Doe [OP]
  • Male Posts: 1,586
    • Bored In Iraq.
« Reply #118 on: Dec 23, 2008, 11:33:46 AM »
I have been waiting for a long time, and no I cant wait!
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #119 on: Dec 23, 2008, 12:14:17 PM »
Lookin' great!
Last post Oct 09, 2006, 07:12:00 PM
by jimbo74
Last post Jan 28, 2007, 05:18:24 PM
by robrub00
Last post Mar 09, 2007, 10:59:35 AM
by yotadork83
Last post Jan 30, 2011, 08:02:15 PM
by x91crawlerx
Last post Sep 06, 2016, 09:35:25 PM
by daniresch
