1979 Toyota Pick up, 3.4 engine swap 5VZ-FE
Started by Redline_MI, January 08, 2016, 05:52:16 AM
Redline_MI
Hey Guys, picked up a new truck about a year ago, but haven't had much time to drive/mess around with it. I am looking for feedback on what I have and what needs to get done/ redone.
79 body, 82 frame,
Professionally swapped engine by RTI in Denver CO, 5VZ-FE, 3.4 liter, manual, (all out of a 99 4runner)
Detroit locker Truetrac front and Rear 4:88 gears
BFG, Mud Terrain T/A 33x12.5
Grant Steering Wheel
Flowmaster muffler
I just installed a Scangauge II in the dash
My list currently is this.
General
- Upgraded master cylinder
- Tube doors *maybe
Front Axle
- Marlin Heavy Duty knuckle gusset kit
- Marlin/ Davez / low range,  shock hoops /tower
- Front frame reinforcement
- Remote Diff breather Done
- V6 caliper swap
Rear Axle
- Davez or low range rear upper shock mount
- Potentially redo the lower shock mounts
- Do something to get rid of the sping blocks
So take a quick run though the pictures and let me know if you see any other items that need to be addressed, thanks!!
http://s368.photobucket.com/user/hillsas/embed/slideshow/79%20Toyota%20Pickup
79 Toyota Pick up
V6 Swap 3.4 5VZ-FE,
redneckcustoms13
Personally I'd ditch that chain drive transfer case in leu of a gear driven case(rf1a) where's the rest of that trac bar? He could be your friend if he is installed.
01 double cab hunting truck
06 tacoma street truck
OVRAROK
 :popcorn: just got done with the slideshow, nice start :yesnod:
Redline_MI
Quote from: redneckcustoms13 on January 08, 2016, 06:02:13 AM
If I have the time and money I would def plan on changing to a gear drive, maybe even move to 4.7 gears, I don't think i really need two since I am wheeling in MI, mostly sand, mud and dirt.
Traction bar is kinda on the list but at the end, I will determine after wheeling more if I need it sooner than later.
79 Toyota Pick up
V6 Swap 3.4 5VZ-FE,
redneckcustoms13
You'd be fine with a single 4.7 case. I run one in my 80 short bed and love it.
AlohaDave
ALOHA REDLINE_MI
BOY AM I ENVIOUS OF UR 3.4 SWAP ! ! !   I BET THAT'S A LOT OF FUN IN A 1st GEN.
KEEP POSTING UP AS U GO , PLEASE.
Redline_MI
It is fun, but man at low speeds around corners it wants to constantly squawk the tires, no good for a neighborhood.
79 Toyota Pick up
V6 Swap 3.4 5VZ-FE,
Redline_MI
Oh yeah, I pulled the transfercase and trans shift leaver ball seats, one crumbled as I took it out the other was gone......WTF, how did this thing even work with it missing (Trans was the one missing)
Order already in to Marlin for heavy duty seats and socket
I wanted the short throw shifter kit from marlin but 300 bucks is just to much.....
79 Toyota Pick up
V6 Swap 3.4 5VZ-FE,
Redline_MI
So my trans shifter and transfercase shifter only had one gasket, some show a gasket/oil slinger/gasket.
79 Toyota Pick up
V6 Swap 3.4 5VZ-FE,
