Power steering bleeding
Started by T2crawlfun, January 01, 2016, 07:02:26 PM
T2crawlfun
Hope some one can help. 1990 SAS with fluid assist. Really having trouble with pumps. Running 38.5" IROK bias ply. Very bad foaming problem , have tried tranny fluid and p/s fluid. Levels go up and down. Inline cooler. Any input would really be helpful. Thank you !! Happy New Year !!
90' SAS,v6,D/L front, spool rear, rear disc., dual crawl box, 4:71,5:29,long fields, twin stick ,39.5" Bias IROK's, TG rear sump oil pan, long slide drive shafts, disc parking break,2 meter radio, Exo cage, sliders, Warn 8000s winch,MC bumpers, TG diff armor, Bud built CM. :)
When I installed power steering in my 86 it took forever to get it to stop foaming up. I just kept adding fluid until it finally settled in and stopped foaming or should I say purging the air in the lines and cooler.
Cheesemaker
Toyota uses tranny fluid for power steering, NOT power steering fluid.
They say to bleed the system, is to put the front end on jack stands, and slowly crank the steering wheel back and forth slowly.  Some people claim that they have to do it for 20-30 minutes, let it cool down, and do it again up to 3 or 5 times.  Some also say not to go lock to lock.
T2crawlfun
Thank you very much for the input ! Still not sure to use tranny or power steering fluid ??
T2crawlfun
Thank you R.N !! Amazing when I read a second time !! :)
Cheesemaker
Quote from: T2crawlfun on January 11, 2016, 01:15:04 PM
Don't use power steering fluid.  Toyota designed their system to use ATF.
OVRAROK
here is an extra factory sticker
Sent from my HTC One_M8 using Tapatalk
mudmaster
Quote from: Cheesemaker on January 10, 2016, 10:04:00 AM
I do this, but without the engine running at first.
Time to go wheelin!
T2crawlfun
Still in surgery , so far so good. Got to finish before Hammer Time ! Thank you every body for the info !!
