http://www.sdsefi.com/techheader.htm
any input on good location for oil return line in the oil pan? top bottom front back?
you can go a couple different routes. if you have the later model block and you want to machine it to match the factory configuration, you'd need to drill and tap the port on the driver side of the block close to the bell housing for the oil feed. as far as the oil return goes, there is a flat part of the block near the oil pan that would need to be drilled and a fitting made to drain the oil back into the pan.Or you can go another route, on the passenger side of the block, you can use one of the oil pressure sender ports to supply the oil to the turbo and then you can make a fitting to attach to the side of the oil pan to allow the oil to return back to the pan.when i first put my motor in the truck, i went the second route. Only because the machine shop was too much of a sissy to drill and tap the block for the oil supply. but i did still return the oil to the pain with a fitting. But when i get finished with my build, the oil return will be going directly into the block like it did from the factory.I hope that helps or makes sense to you.
I know what you mean. I haven't had any issues yet when the oil return was going directly to the oil pan. Thats one of the reasons i'm putting it into the block like the factory has it.
Started by babypig Toyota Pickup/4Runner Tech 1979-95
Started by Stubs Toyota Pickup/4Runner Tech 1979-95
Started by KRANKER General 4WD Discussion
Started by fanto57 New Member Check-In!
Started by fanto57 Parts For Sale
