1982 Toyota Pickup Crawler for sale $6500 Tehachapi,Ca
Started by Gixxer Jon, November 23, 2015, 07:11:56 PM
Gixxer Jon
Sad to say, but due to loss of employment. She is up for sale!
1982 SR5 4WD Crawler with all the goodies. I'll try to list everything I can think of.
193,808 miles
22R Runs good (all stock), tuned up, TG bomb proof trans & motor mounts, new battery & cables, smokes a little on startup
L52 Trans shifts , MC shifter socket & bushing
Dual ultimate (223:1) with MCO7 & 4.7 gears from MC, MC 5 pattern flanges on T-case, front and rear axles, low profile drain plugs, heavy duty shift springs
TG crossmember with grade 8 hardware
Custom Drivelines
Front driveline is 85 CV long slip, square tube
Heavy wall rear driveline, new u-joints, balanced & runs smooth
2nd gen steering box, tapped for hydro, SKY billet steel pitman arm, 3/4" heims on all steering
ARB Compressor & switches
ARP lockers front and rear with Yukon 5.29's
3" body lift
Hydro assist steering
Front axle (85) has 30 spline Bobby Longs, High pinion 3rd with ARB & 5.29's, solid spacer, MC 5 pattern flange, trussed armored, all new bearings, seals, TG backing plate eliminators, TG Felt retainers, new hardware with trail gear 6 shooter arms & knuckles, Hydro assist with external PS cooler, V6 calipers, vented rotors, IFS hubs, 1" wheels spacers
Rear axle (IFS) has been stripped & rebuilt with V6 3rd, ARB with yukon 5.29's, solid spacer, MC 5 pattern flange,  trussed & armored, all new bearings/seals, TG disc brakes, 1" wheel spacers
Brand new FJ80 master cylinder & new dual diaphragm booster (stops very well for riding on 37's)
37x12.5x15 Good year MTR's with lots of tread left on steel wheels and brand new MTR spare on alum wheel
Has 3rd gen RUF with SKY boomerang shackles, drop box- front axle moved 4" forward, & F150/buggy leaf rear (rides & flex's awesome)
Shock hoops front/ rear crossmember with /\
12" 5150's all the way around
Braided brake lines F&R
Custom tube front bumper with XRC8 8000lb winch
DOM Sliders
Custom rear bumper with receiver & recovery point
Custom rear quarter/ bed  sliders
Custom fit long bed bobbed 19 1/2" to fit fender wells over rear axle since the rear is stretched 10"
Interior has excellent condition PRP seats with Simpson 4 point harness's
Peaked and tuned Uniden Cb
Sony CD player with 2 6x9 speakers
Interior lights on both sides of cab
Floor has been refinished with spray on bedliner
Rustoleum flat khaki paint job, body is pretty straight (just minor dings/dents) NO RUST
This is a turn key krawler, clean title, street legal,  no smog.  All lights, wipers, turn signals, heater, etc. work as they should.
Truck runs good & drives straight. Ready for Hammers, Rubicon, whatever.
Truck also comes with custom built tube doors, A set of staun's and brand new (not installed) ARP knuckle studs and hardware
Located in Tehachapi, Ca
$6500.00
Feel free to call or Text:  661-364-6040
Hillcrest Crawlers
_________________________________
||_________||_________||__TOYOTA_||
||_________||_________||__________||
http://board.marlincrawler.com/index.php?topic=67011.0
jangelfire
Khan_43
dudethedude
