Wire on back of head?
Started by Hyena, March 30, 2005, 10:45:18 AM
What does the wire do that goes from the back of the head to the firewall?  It kina looks like a ground or maybe it stops the engine from moving too far.  I just found mine unbolted yesterday and wondering if it is needed?
BLACKDOG
Doesnt that get in the way when you cut your hair??  :headscratch:
Its a ground.  I dunno if you relly need it, if yours was unbolted I would say prolly no, but I would just bolt it back up
Mine bolts through on of the intake manifold bolts, just onbolt it, slide it over and bolt it back down :thumbs:
              -Ronald Reagan
Prismo
89 toy
put it back on my dad forgot his after swaping the motor in a 80 and it fried the wiring to the alt. and tosted the alt and regulator
donkeykong
It is a ground and deffinitly put it back on.
kyle_22r
i've heard it's mainly to prevent electrolytic corrosion since the head is aluminum and the block is iron.
86 4runner
mine busted when i did the body lift cause i didnt know it was there. i propaly drove around for 2 months before i noticed it it wasnt connected it didnt do anything bad but its supposed to be there so you should put it back on. they wouldnt put it there if it didnt have a purpose
86 4 Runner SAS, 37 inch Toyo M/T's, E-Locker rear, Lock Right front. 30 spline Longs, 5.29's, Dual Cases, Warn XD9000i
guywithuglyyota
Quote from: kyle_22r on March 30, 2005, 07:08:26 PM
this is what its for
My buddies truck doesn't have it either.
mtntoy
I too have heard that it is to help prevent electrolysis on the head, and as everyone has said its supposed to be there for a reason; multiple grounding points are always good for electrical items anyhow.
