Author Topic: Looking for Info - Bronco C4 Marlin Crawler specs/fill/assembly  (Read 1344 times)
12-Pack Jeff
  • Member since Aug '15
I recently picked up a C4 w/ a Marlin Crawler for my father's rig.
It's attached to the C4 already, but the Dana20 has been removed, I'm looking for some assembly/install instructions or any other related info for this item.
I searched the forum but didn't find anything.  If anybody has info that would be awesome.  Thanks guys
Jeff jeff468@gmail.com
SoCalBroncos
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
12-Pack Jeff [OP]
more then likely you have an advance adapter between the two http://www.chassisunlimited.com/advance-adapters-ford-c4-3-speed-automatic-transmssion-to-toyota-truck-gear-driven-transfer-case-with-23-spline-input-shaft-adapter-kit.html
Thanks dude!  Yes, that's the adapter we have.  We got everything mated up on Friday then installed the motor (351W), Trans (C4), Marlin Crawler and Dana 20 all together as 1 piece today...  What a pain in the butt - even with the grill and core support removed.
Then found out we need a body lift because we cant get the tail end up high enough... D'oh!
Do you know if any fluids are needed in the adapter you linked to?  I figured it was just a tailshaft adapter, but after seeing it has bearings and a spline converter, i'm not 100% sure.
Thank you very much for your guidance.
12'r
Last post Feb 13, 2006, 08:23:06 PM
by 79coyotefrg
Last post May 29, 2012, 08:43:05 AM
by BigMike
Last post Oct 28, 2016, 04:07:13 AM
by Floridaedd
Last post Dec 13, 2018, 10:19:13 AM
by L5wolvesf
Last post May 31, 2022, 04:43:52 AM
by tjoey4685
