37" Irok Radials keep lossing air
Started by toy4kid, August 11, 2015, 01:26:03 PM
toy4kid
Any ideas to keep from leaking at the bead. They have been remounted. Wheels are not chipped or dented, or rusted. Seems to be a typical issue. The tire shop has used mounting sealant with no success although it slowed it down.
Dingman.
You said they have been remounted, so are the beads ripped or torn at all?
Id go over the whole tire with a soapy water to see where the leaks are from and make sure there are not any holes anywhere else.
daniresch
jangelfire
Id guess you have a leak somewhere.hmmmmmm???
toy4kid
I'll get picks but they are standard 37" iroks mounted on 15x10 procomp steel wheels- very basic. Have done the soap and it slowly leaks out the bead on the outside bead (where no rock rash occurs). There are no tears or rips in the tire bead in that area either. I've just read alot where others have the same problem and wanted a fix. It takes a month or so to go flat.
