22re rebuild problems need help asap!
Started by mudcrawler87, July 25, 2015, 11:07:09 AM
mudcrawler87
ok so im trying to get into crawling and such and my parents gave me my dads old truck, its a 1987 pickup 22re efi. so i rebuilt the whole engine, pistons, honed the cylinders, and some other stuff. i did it all my self except putting the engine back in the truck, i have all the electrical hooked back up and i, still trying to find a vacuum hose diagram to put the hoses in ghe right place, i replaced the distributor with a brand new one and i replaced the relay under the dash the open relay. i have done all this work and when i go to start my truck the fuel injectors arent opening neither is the cold start, i checked all the wiring and none of it seems bad, i dont knwo what else to do i need some major help! if anyone knows what my problem is please let me knpw i have no other ideas this was supposed to be a twe week project its turned into a 4 month project and almost 2 thousand dollars. i really just want to hop behind the wheel and drive her asap so please help me! ive looked allll over the internet and ive replaced all the parts they say to and still no fuel to the cylinders, not a drop.
OVRAROK
mudcrawler87
yeah fuel pump is working, the injectors are opening at all and i pulled the cold start off the efi and it wont fire either
OVRAROK
So if you disconnect fuel line going into injector rail, turn key on fuel flows out
OVRAROK
Have you ruled out the afm, it controls fuel pump
OVRAROK
1985CRAWLER
1985CRAWLER
do you have all the main ground wires connected?
should be one from back of head to body on fire wall, engine block to frame, one under the intake manifold coming off the harness and theres another that connects the negative terminal on the battery to the fender.
truck will not start if something isnt grounded or will have intermittent starting problems.
mudcrawler87
all the grounds are hooked up, fuel to the rail and everything but its just the injectors and cold start that wont open, i have no other ideas what so ever if you guys have any ideas to help im open to try anythin, i just want to be able to driver her before my 17th birthday
1985CRAWLER
Quote from: mudcrawler87 on July 25, 2015, 06:25:22 PM
double and tripple check everything.
do u have access to another ecu,injectors,igniter ,etc. to swap them in to see if something is faulty?
some good info here:
http://www.toyotanation.com/forum/267-1st-generation-1984-1989/327429-87-4runner-22re-injectors-not-firing.html
