Air Compressor pump HP requirements.........
Started by emsvitil, July 09, 2015, 05:46:17 PM
emsvitil
Are air compressor HP requirements linear to speed and pressure.....
Say you have a pump that's rate 3 HP 150 psi and max rpm 1200.
If you only have a 2 HP motor, will it work if you have the cutoff psi at 100psi rather than 150psi (2hp/3hp * 150psi)
or
gear it so it only goes to 800rpm
or
some combo of speed and pressure reduction?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
