DUAL TRANSMISSION
Started by HACKJOB, March 28, 2005, 09:08:38 AM
HACKJOB
Gents a couple of questions:  Has anyone experimented with mating 2 transmissions together.  From what i imagine if you were to do this you could have the low range of a 4.7:1 using 1st gear/1stgear & low range or how about reverse/reverse & low range but you could also have a myriad of other gear combinations which might make it possible to run larger tires without changing out the ring and pinion since you could run 4th gear/third gear 2  transfer case in 2 wheel drive.      :eyebrow:
Rebeltilldeath3
It's really not that hard to change your ring and pinion.
FIREBALL
Do a search, there's a thread here somewhere, and one on the pirate board too.
Yup, a couple of people got really excited about this and did some work and now where are they?
ntsqd
My grandad did it with a Ford Model TT truck in the Twenty's.
Cross threaded is tighter than Locktite
mike_belben
Quote from: BigMike on March 28, 2005, 10:16:58 AM
out wheelin em.
mike_belben
ive only heard of one breakin, you?
werty
http://pirate4x4.com/forum/showthread.php?t=132841
about 2 years ago i saw this on pirate.
Final gear ratios with two g52s and 4.10s:
1st & 1st & low 144.3 to 1
reverse & reverse & low 210 to 1
g52 to w56 207 to 1
reverse & reverse 92.1 to 1
1st & 1st 63.3 to 1
1st & 2nd 37.5 to 1
1st & 3rd 23.3 to 1
1st & 4th 17.1 to 1
1st & 5th 13.6 to 1
5th & 5th 2.92 to 1
5th & 4th 4.3 to 1
4th & 4th 6.1 to 1
3rd & 4th 6.9 to 1
2nd & 4th 10.5 to 1
1st & 4th 17.1 to 1
Some tech
I posted this on pirate about 6 months ago. I gave up on the idea after both w56s I have sitting in my backyard need syncros or gears. but i do have two tcases now. so I'm going to do the dual cases when I get the money for the mc07-r10
