Author Topic: 1981 2wd 20r fuel issue questions BUBBLES in filter  (Read 2455 times)
tgmaul88
  • Turtle Points: 30
  • Male Posts: 985
  • Member since Feb '12
  • Im still alive
« on: Jun 18, 2015, 03:28:45 PM »
I have a mega Lego build but everything's there its a 20r with a weber short bed. Good tank, good pick up screen, was new filter. New lines from hard lines from tank to carb.  I had a good working pump on it, no issues for a month then randomly yesterday it was acting like it was out of fuel. I limped it home and put a half tank in it and still same thing starts.  Runs. Idles and will drive until it runs low on fuel I look at the fuel filter and its 1/4 full with a steam of air bubbles and fuel  coming down.  All lines except the hard line. Still getting air in filter. Took gas cap off no difference
Blew out all lines  in let, outlet, and vent lines near intake. Loosing interest in a carbed fuel system...... Any ideas
OVRAROK
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
It may sound funny but double check lines going into filter, AutoZone and Napa are different, try swapping lines at filter
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
Bought a new fuel filter to try will see tonight
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
Crazy thing is it "was" working just fine for the life of her to me
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
It just doesn't seem like the pump because the fuel into the filter is bubbly like its pulling air through
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Is it hot?
Could be fuel vapor and not air.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
No even on cold start .  my only other guess would be a bad hard line.   But with no visible leak it seem unlikely
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
With no fuel leak, the problem would be before the fuel pump.
(ever had a straw with a pinhole in it?)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Or pinhole in fuel pump diaphragm
Check oil for fuel.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
I'm going to bypass the hard line and see what happens,  already dumped like 4 hr into trouble shooting and swapping stuff. All for bubbles.  The straw picture looks best.  I also thought to try putting a line in a gas jug to see if its still pulling air
Cheesemaker
  • Turtle Points: 1346
  • Male Posts: 4,525
  • Member since Sep '04
Works fine, UNTIL it runs low on the tank?  Correct?
I would look at the pickup in the tank.  Swap that out, and see what happens.  Gotta be a pinhole there, thats sucking fine when covered in fuel, and then when it gets low, it starts sucking air.
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
Update,  so I swapped the return line for the feed line and vice versa and no bubbles. The hard line has a leak. Trucks back up doing donuts now 2wd 20r welder rear
Last post Jul 27, 2007, 09:00:53 PM
by Proteus503
Last post May 14, 2008, 08:23:27 PM
by yota18
Last post Mar 28, 2009, 02:10:06 PM
by V-Man
Last post Jun 10, 2009, 07:58:39 PM
by Slolyfe
Last post Nov 22, 2011, 02:08:33 AM
by Rocksurfer
