Help!!!!!!! wagoneer springs
Started by AJ, March 27, 2005, 05:01:21 PM
AJ
I am converting a 2 wheel drive to a 4x4 and need help. I have a set of wagoneer springs that i will be running up front and need some dimentions. I am making my own spring mount, and need to know outside to outside on springs, so i can complete this front end. Its got a stock toy front end goin in it so someone please help!!!!!!
#1
from center of center pin to the center of the other center pin is 29".  Waganeer springs are 2 1/2" or 3"?  Depending on how wide they are you can figure out the dimensions for the spring mounts.You can make it about 1/4 inch wider on each side so there is room for error.  It won't hurt it.
AJ
Thanks alot. My axle is at my dads and havent had a chance to go measure. You saved me a trip.
