1995 Toyota 4runner 5vzfe swapped
Started by dweinberg01, April 21, 2015, 11:10:24 AM
dweinberg01
1995 Toyota 4Runner
1997 5vzfe swap- referee approved and smog legal
A340F automatic transmission
Marlin Crawler dual transfer cases-2.28 front 4.70 rear 30 spline input-twin stick
BudBuilt dual case skid plate
Heavy duty rear CV driveline- built by Hi-Desert Driveline
Square tube front driveshaft
6" lift with All-Pro springs
Trail-gear hi steer kit
Trail-gear steering pump kit
4-35 12.5/15 Cooper Discover SST tires with nearly 90% tread 1 spare with 100%
Solid front axle from a 1984 Toyota pick up
4.88 gears front and rear
Spartan locker in the front
Aussie locker in the rear
Longfield inner and outer axles with Longfield Hubgears
Smittybilt XRC10 winch with 100' of synthetic line.
Marlincrawler rock sliders
Trail-gear front bumper
Drop down tire carrier. (Rear bumper is made of 4x4 square tubing and has the capability to be an air tank if you care to weld a bit)
Spare driveshaft and stock axles included in sale.
Truck does 70mph out to the Hammers with no issues.
Bad:
Back up lights don't work.
Small leak from the back of the motor somewhere- not sure if it's the pan or the rear main seal
$8,000 obo
Located in Apple Valley, Ca
Contact me at 7six0-96three-nine429
Pics of the interior:
tootallsteve
I'm interested in this truck , Do you sill have it and can you have it smoged for the sale. thanks Steve 559-977-9139 Going to Arizona Monday and will be coming back your way around april 30th or May first. You can text me or call if you still have it .
