Author Topic: Hybrid R151F with R150F gears  (Read 3738 times)
Jeep_junkie
  • Member since Nov '12
« on: Apr 09, 2015, 06:10:11 AM »
Hi everybody. I'm sure this question has been asked before (though I didn't have much luck searching for an answer), but can I swap the R150F's taller 1st and 2nd gear into my R151F? I would appreciate if somebody could list the parts required if this is possible.
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
Re: Hybrid R151F with R150F gears
« Reply #1 on: Apr 09, 2015, 07:29:15 AM »
I don't know if it's possible or not, I would think so but not without some specialty tools,  but I've been in the same boat and I just swapped the tail and bell housings from the 151 to the 150.
helipilot77
  • Turtle Points: 1018
  • Male Posts: 1,729
  • Member since Jul '12
  • Seattle, WA
    • My build thread
« Reply #2 on: Apr 09, 2015, 08:34:13 AM »
Marlin offers the different first gear on his R151f rebuilds so I would imagine you could do it
LittleSteve
  • Turtle Points: 170
  • Male Posts: 943
  • Member since Jan '14
« Reply #3 on: Apr 10, 2015, 01:25:08 PM »
Just out of curiosity... Why not fit a r150 as a whole
Refusing to fit in or comply.
Easy is not worth anything.
Prismo
  • Turtle Points: 8461
  • Member since Oct '03
  • Living in the green house
« Reply #4 on: Apr 10, 2015, 02:08:14 PM »
It has a chain drive transfer case rather than the gear drive transfer case that is part of the r151
LittleSteve
  • Male Posts: 943
« Reply #5 on: Apr 10, 2015, 02:23:49 PM »
Ah, the r151s here are chain driven from factory...
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
« Reply #6 on: Apr 17, 2015, 03:12:11 PM »
I'm running a hybrid just like you are asking about. You have to change the entire cluster. So like was mentioned.....R150F guts in R151F case. Everything inside aside from the gear ratios is the same. Must be the early R150F from a 3.0 however.
1st and 2nd on a R151F might be good for crawling but it sucks on the street.
88 Pickup SAS'd, 3.4 V6, R151F Hybrid, Dual Ultimate, Triple sticks, 35's, 5.29's, HP front, V6 rear, Aussies, 63" Chevs, Anti Wrap Bar, Warn 8274 on Home Built Bumper
4WU linked 86 Xtra Cab build in progress
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #8 on: Apr 17, 2015, 09:07:43 PM »
The R151's were put behind the turbo charged 22re's.  The R150's were for the 3.0's.  I don't have issues with the R151's taller 1st and 2nd gears.  Just that you have to grab 2nd rather quickly when launching off the line.   :yupyup:
2manytoys
  • Male Posts: 583
« Reply #9 on: Apr 18, 2015, 10:21:15 PM »
ovraok, he was asking about swapping out internal parts into his same R151F case. Doing this lets you keep your 4 cyl T-cases and still fit the 22RE.
You are correct that a R150F from a 3.0 V6 will not fit the 22RE or the 4 cyl gear drive cases unless you get an adapter. You CAN put those guts into the R151F cases no problem though. Exactly what I have done. Later when I did my 3.4 swap, I swapped on a 3.0 bell housing so it would bolt up to the engine.
Last post Nov 27, 2005, 06:18:08 AM
by ccannon222
Last post Dec 02, 2009, 09:17:09 PM
by seafarinman
Last post Jul 29, 2010, 07:28:42 AM
by 2manytoys
Last post Dec 19, 2014, 11:01:31 AM
by Nation
Last post Aug 20, 2021, 04:57:48 AM
by RB
