cold start issue
Started by 4-lo, January 15, 2015, 05:02:15 PM
4-lo
Was wondering if anyone else is having the same issue/problem.
95 3.4 taco
battery= yellow top
Issue is on a cold mornings it dont want to kick over.  Sounds like the starter, but yet about noon when its warmer it starts just fine.
The funny thing is im not in alaska weather condition, im in fresno 😠.
Could it be bad grounds or is it a sign that the starter is weak.
emsvitil
Check the battery connections
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
1985CRAWLER
clean grounds/check them.
not sure if the 3.4 has them but check the efi fuse and bulb.
Pyroslinger
GEL Mat batteries are not a good choice in cold weather climates. Tried All Colors and sizes. Lead Acid for mountainous regions, such as Montana is the only way to go.
"Never Judge A Book By The Cover"
