open gas cap and a whooshing noise is heard
Started by tanman2003, March 23, 2005, 12:01:46 PM
tanman2003
so im guessing that there is a vacumme or too much gas vapor pressure built up in there.
either way im thinking its the charcoal canister, or one of the lines to it, is clogged.
anyone know why it would be bad or what would happen if i diddnt fix the problem?
maybe i could just ignore it? :_oops:
This is perfectly normal. The fuel system is designed for the engine to suck vapors out of the tank so that when you open your gas cap there are none. On newer trucks there is a solenoid that will delay about 30mins before allowing fresh atmospheric pressure to vent back into the tank.
tanman2003
Brandon
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
BLACKDOG
mine always does that, and I usually fill up between a quarter full and E
              -Ronald Reagan
tanman2003
usually empty, but i think it does it all the time no matter what the level.
mudaddict
mine does that usually on really low gas! i dont know the only times i fill up is 1/4 a tank or lower
I work At
All Pro Off Road
guywithuglyyota
Makohon
same here... newer older... they have done the same with me.... volvo... wrx... newer yoda... same thing
