OFF SET RIM or GRIND the calipers. w/ picks
Started by mountainyoda, July 12, 2014, 09:24:48 AM
mountainyoda
 Want to install V6 calipers on 83 pickup. Will offset rims work, or do I halve to grind also?
got pics?
Goldrush
It's all in what u want to do. Either way works. Personally offset rims work good.
1985CRAWLER
what type of rims do you have? stock?
i have v6 calipers and fj rotors on my 85, but i have 2.5" bs rims and ifs hubs and spacers so i had no clearance problems.
i hear u can take a little bit of material of the caliper but it doesnt sound to appealing.
Cheesemaker
It depends on the wheel your running.  Aluminum wheels are able to be cut (machined) with more clearance for the caliper from the manufacture.  But steel wheels are not.
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
onemanarmy
I have stock IFS wheels from an 86 4 runner ion a solid axle with V6 calipers and just ground down some of the 'fins' on the outside of the caliper.   Not much material was removed.    No need to buy new wheels or get spacers just to clear less than a quarter inch.
