Needs help with 86 toyota 4x4 truck pahleeeze
Started by yota86pu, June 19, 2014, 06:46:23 PM
yota86pu
I have a 1986 toyota 4x4 truck its a base model pickup with 22r engine, and I need a new VSV (vacuum switching valve). The one thats blue on passenger side. The original toyota P/N:8957035170 toyota no longer makes am having trouble finding a aftermarket part....any help?
Thanks!
1985CRAWLER
http://www.toyotapartsoverstock.com/p/TOYOTA__/VALVE-ASSY--VACUUM-SWITCHING/4055783/8957035170.html
NOS oem part.
found them way cheaper on ebay used but not sure if u wanted new or not.
could also try your local wrecking yard with toyotas in it.
yota86pu
Thanks was looking for new....will give tg hat a shot.
yota86pu
Ok....so I called toyota over stocked parts. ..as the other "Toyota peeps" said the parts discontinued.  Sooo....anybody know a NEW Aftermarket Vacuum switching valve from a different application which would work on my 1986 toyota 4x4 truck?
I really don't want the junk yard....due to the fact the Vacuum nipples break...which is what happened to mine. The valve is blue in color mounted on passenger side fender two vacuum ports on top and electrical plug in on bottom it goes between charcoal canister and carburetor.
Any help much appreciated.
Ted
