1st gen: I need GREMLINS...uh GROMMETS
Started by waskillywabbit, March 21, 2005, 04:42:46 PM
waskillywabbit
Well, I am in need of some grommets, mine are all pulled through and dry rotted, and they all seem to only come w/ the wiring harnesses, so I'm out of luck ordering OEM ones...anyone run into this problem?
I need the following:
(1) Firewall grommet on the passenger side for the main engine wiring harness about 2-3" in diameter
(2) Door grommet that goes on the end of the front of the door where the wiring harness goes into the door
(2) Body grommet that goes into the body right inside the door that has the same wire as above running through it.
Anybody know where I can get these or some other options?  Boneyard is obvious, but I'd rather have somethine new, not already as old as the ones I got.
:yupyup:
UNBREAKABLE
They disappear? I think that I still have mine and that is amazing!
That's how I roll
Salvo
i just went to the dealer and got the ones i needed... Just whent through the diagrams and pointed to what i wanted
yotaboy79
go to a hobbie shop and get some silicone rc car or plane fuel tubing and cut it down the center then cut it to length and put it in you can even get different colors :beerchug:
