And for the cutting, I cut from the top of the bed to the floor then I use a piece of string tied to a washer and slide in into the cut I just made. I pull the string across tot he opposite side of the bed and put it in that cut as well. Then I paint the string with a rattle can and i have a nice straight line across the floor.
I used a spring to mark the line so it is straight. the curve of the spring matched the curve of the bed side perfectly.
Yeah, hang a piece of wood or something over the side of the bed, attach a string, and attach something to the string. Use a marker and draw a line parallel to the string, and if you trust gravity, then you've got 90degrees
Started by ghetto_wheeler Parts Wanted
Started by KYOTA Engine
Started by TacoCrawler Parts Wanted
Started by jetsupra007 New Member Check-In!
Started by Drsj1967 New Member Check-In!
