Author Topic: 83 22r cam and zinc oil  (Read 1896 times)
VincentVanPwn3d
  • Male Posts: 28
  • Member since Jan '11
    • Buy me some coffee
« on: Feb 03, 2014, 12:01:30 PM »
I just got my head back from a local machine company. They hot tanked it, did a leak down and resurfaced it. They said it was sealing good. The cam in it has been in it for 15k and looked great. When I picked it up he mentiined that because it was a flat tappet I need to use a zinc oil. I asked him why, and that I thought zinc was only needed for break in. He replied saying that it should always have zinc in these 80's flat tappet cams and nit just for break in. I never heard this before can anyone shed some experience or opinions on this? I honestly think he just wanted me to buy  his 5 dollar a quart zinc oil.
Sent from my SM-N900T using Tapatalk
86 4runner
22re
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: 83 22r cam and zinc oil
« Reply #1 on: Feb 03, 2014, 12:43:31 PM »
Diesel oil has more zinc in it.........
I use 15w40   (~170k miles)
Newer engine could use 10w30
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #2 on: Feb 03, 2014, 07:03:36 PM »
That's the best, some question using oil designed for a diesel but that's not a problem, now using oil designed for a gas motor in a diesel now you're looking for trouble.
Frank Rizzo
  • Member since Oct '13
« Reply #3 on: Mar 18, 2014, 02:28:39 PM »
i heard the same exact thing when i got a new head at a local machine shop.  guess what?  i just dumped 5w-30 in that pregnant dog and called it good  :biggthumpup:
Mtrdud
  • Member since Dec '13
« Reply #4 on: Apr 10, 2014, 04:28:33 AM »
Yep, diesel oil.
Cheesemaker
  • Turtle Points: 1346
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #5 on: Apr 11, 2014, 02:52:40 PM »
I've always been told by several engine builders to run Delo 400 or Rotella, 30w or 10W-30.  So, that's what I stick with.
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
« Reply #6 on: Apr 11, 2014, 11:18:10 PM »
Diesel oil does have more zinc in it and the 15-40 Caterpillar oil I used to get said it was compatible with gasoline engines.
I used to carry 5 gallon buckets of it in my service truck for customers and many times they did not want whatever was left over and let me have the left overs. I didn't have to buy oil for years.
The stuff works great and I get a LOT of miles out of my engines. I used it in my high mileage engines and old school rebuilt engines and they are still running. Zinc is good for wear reduction. Especially flat tappet cams. Even more so for double and triple spring hot rod engines. Not so good for emissions.
Back when Caterpillar acquired Perkins engines, the Perkins in the Cat backhoes were having oil consumption problems. Rings were not seating on new engines. Ultimately engineers found the problem to be the high zinc content in the Cat diesel oil. New Perkapillars had to be broken in before using the Cat diesel oil. Say's something for zinc additive in engine oil.
I run manufacturer recommended oil in my new Toyotas especially under warranty.
