2rz swap into 90 ex cab
Started by Crunchy Taco, January 29, 2014, 09:42:58 PM
Crunchy Taco
im helpin my cousin work all the bugs out of his 90 ex cab, and theres quite a few things to address...he blew his 22re a few years ago and then decided to do a v8 swap...i tried to talk him out of it knowing he didnt have the money to do it properly but he did it anyway so i helped as best i could...long story short it never really worked out for him so i started gathering wiring off a 2wd taco i came across and i already had a 2rz i been hangin on to for a couple years....so now we do work so he can once again have a reliable wheeler
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
Crunchy Taco
#1
what were guna get him started with is:
98 2rz motor
w-56 trans with stock duals he picked up for 500$
hes got a dana 44 front and a 14 bolt rear
Custom built heim joint high steer with assist
sittin on 35 boggers with 4.10 gears
just guna get him set up with a good power plant and decent trans and case then he can add more goodies to the axles he already has.
Crunchy Taco
Pulled a bunch of heavy stuff out
Crunchy Taco
Pulled all the old wiring out and everything else that's not guna be used
Crunchy Taco
Started the interior wiring, more pics coming soon
HogCanyonHopper
R.DesJardin
R.DesJardin
Tungsten Slayer
Crunchy Taco
worked on my tacoma the last couple days, hopin to hammer a bunch of stuff out on the cousins truck tomara and this weekend...  :hammerhead:
Crunchy Taco
Got some more done on the dash wiring. I cut the plate that holds the turn switches off the taco colum and used it on the 3rd gen column.  Plug and play
Crunchy Taco
I was able to use the taco ignition and turn switches on the 3rd gen column to keep the tilt column. The taco column was no tilt.
Crunchy Taco
Got the dash in and made the taco no tach cluster fit
R.DesJardin
Looks pretty much how I laid mine all out/in. It just seemed really easy since 99% of the connectors were the same, and everything works!
R.DesJardin
Crunchy Taco
i know i was surprised everything had the same plug..i had to extend i think the brake light sensor and the clutch sensor but that was it
Crunchy Taco
so whats the deal with the 2wd taco dash wiring having no clutch start cancel? this is the third 2wd inter harness ive messed with on a couple diff projects and im assuming they dont have it...some times i like to push it and start my truck without hopping up in the truck other than that i think its ok not to have it...
R.DesJardin
Didn't notice that.........cuz I run an auto!  :greengrin:
R.DesJardin
Crunchy Taco
Crunchy Taco
Used the Tacoma column cover pieces made them fit around the tilt lever
Crunchy Taco
Ran the rear harness wiring
Crunchy Taco
Bellhousing with a bottom inspect. Plate I made. I made the same one for my Tacoma
Crunchy Taco
Got the fuse box mounted
Crunchy Taco
Fixed part of the core support that dude cut out to fit a radiator or somethin I'm not really sure but it's pretty ghetto
Crunchy Taco
Got rid of the old rusted battery mount and built a simple new one
Crunchy Taco
#23
One of the things on this truck that needed attention was the steering.  Here's what I came up with. 3/4 heims, 3/4 misallign spacers, 3/4 bolts, 1 1/4 x .120 DOM
Crunchy Taco
Pics
Crunchy Taco
Should hold the battery until my cousin Aaron makes something a little more crawler worthy
Tungsten Slayer
That's right, just lay that nice newer harness in there :therethere:...eeexxccellent
Crunchy Taco
i walked off for a min and when i came back all the wires were right where they need to go, weird
Tungsten Slayer
Crunchy Taco
