Author Topic: How to set timing on a rebuilt 22r  (Read 1199 times)
1haoleboy
  • Turtle Points: -241
  • Male Posts: 98
  • Member since Dec '13
  • if no fit just put spit
« on: Jan 07, 2014, 07:04:57 PM »
Gunna be building my 83 22r and was just wondering what is the best method for setting the timing.  I know it's vague but I'm new at this.  Thanks for ur help!
81 shortbed
  • Turtle Points: -5
  • Male Posts: 329
  • Member since Nov '13
Re: How to set timing on a rebuilt 22r
« Reply #1 on: Jan 09, 2014, 03:10:15 AM »
Go o lc engineering's site. They have a tech page with timing instructions on it
Sent from my MB886 using Tapatalk
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #2 on: Jan 12, 2014, 09:25:26 PM »
I usually set the initial timing by setting the crank at 5* before TDC(top dead center), and install the distributor so that rotor is just before spark plug one's terminal with the adjustment range of the the distributor housing in the middle.  From there it is usually just some fine tuning of the distributor.  It may take a couple of tries to set the the dist right as the shaft will want to rotate as it meshes with the gears.  If you find yourself running out of room for adjustment, pull the distributor and rotate the shaft a tooth or two at a time in whichever direction is needed.
Download the FSM from here or buy one off the pay site if you don't have one already, it will all but hold your hand through the tear down/rebuild process, don't bother with a Chiltons or Haynes manual, they are just about useless.
Last post Nov 07, 2004, 04:28:22 PM
by Mike D
Last post Nov 11, 2004, 10:46:09 PM
by Makohon
Last post Jun 24, 2006, 05:37:32 PM
by toy80
Last post Mar 11, 2007, 06:35:33 PM
by wrenchtech
Last post Aug 20, 2008, 04:43:12 PM
by 79coyotefrg
