Drive line vibration, what to do?
Started by hilux-1983, November 05, 2013, 10:50:52 AM
hilux-1983
My buddy lifted his cherokee 4 inches. Now has a drive line vibration. Guess we have to lower the trans to compensate for the ds angle?
Cheesemaker
Is the rear pinion angled up towards the t-case output?  And does it still have the slip yoke output on the t-case?
hilux-1983
Quote from: Cheesemaker on November 05, 2013, 03:13:46 PM
Yes and yes(it's about an inch out of the output though)
HogCanyonHopper
Quote from: hilux-1983 on November 05, 2013, 10:50:52 AM
you need a dl with a double cardan joint
merace19
There is a spacer kit for the cherokee to lower the transmission some.  But getting the angle of the rear pinion 2 degrees less than the output of the trans is the best set up.  You should not need to do a SYE with a Cherokee cause the drive shaft is way longer than a TJ. And I had at least 5 jeeps with 4 inch lift with no issues as long as the pinon angles are set right..
I am a Jeep nut and just got a 4runner to mess with.
merace19
can you post a picture of the drive shaft and pinion angle? You have a angle finder? They are like 5 bucks at Home depot
