spooled rear
Started by 83Yotabeast, October 24, 2013, 01:17:42 PM
83Yotabeast
i have an 83 toyota pickup its spooled in the rear and open in front should i get airlockers front and rear or leave it the way it is
if parts aint flyin you aint tryin
toyodaaddict
what do you use the truck for? have you geared yer axles yet? are you running longfields? if not id suggest leaving the front open till you get some. your question leads me to think youre new to this kinda stuff. if thats the case i suggest leaving it as is and get to know the truck and what you want . you can go a long ways with a spooled rear and open front.
Leave the spool alone and add whatever you want to the front.
