I just wanna be able to post in classifieds
Started by doylejones, October 21, 2013, 03:38:42 PM
doylejones
doylejones
:welcome: Thanks for checking in doylejones :wave:
What year Runner is it, is it 4cyl or 6cyl, and what are your plans? :hyper:
doylejones
Its a 91 and it had a 3.0 in it but im looking to find a 3.4
monyman
2001 Tacoma double cab SR5: 3.4l V6, Diamond axles, 5.29s, duals, ARBs, PSC hydro, 4 wheel discs, 38.5 TrXus and stuff
Quote from: doylejones on October 21, 2013, 05:56:42 PM
Cool! Despite what everyone says, the 3.0 is a good engine if you rebuild it and take care of it. But of course the 3.4 will blow it away. How long have you owned the 4Runner? I have three very close friends who wheel 2nd gen 4Runners. They are my 2nd favorite 4Runner body style :beerchug:
Try and find the non U.S. head gaskets, that is the whole problem with them. When asbestos was banned Toyota had to scramble and come out with a different set of gaskets, they are not as good as the gaskets that were originally planned for the 3.0's. This is also why pre-90 3.0's don't seem to have the problem.
doylejones
Ill have to look for some non U.S. head gaskets and i just picked up the runner.
RS, are there any all-metal high performance aftermarket head gaskets available? TRD? Blitz? HKS? Cometic?
doylejones
Okay so I have a question. Im putting a manual tranny in my runner and it came with an automatic. Will I have to change anything with the computer?
doylejones
Quote from: doylejones on October 23, 2013, 05:48:59 PM
I'd like to reply to your question with a question: How attached are you to this 4Runner? Have you considered selling it and instead build up one that already came with a manual transmission?
Quote from: BigMike on October 23, 2013, 10:22:27 AM
I would imagine there are but I'd still prefer the type that were originally in the engine design. Had one go in the 91 back in 93, Toyota ended up replacing the whole engine since the block would no longer seal with a steel gasket. The leak was very slight and put a good notch on the deck over time that couldn't be fixed. Last one I ever want to deal with.
doylejones
im not attatched to it its just a project i have.
Quote from: doylejones on October 28, 2013, 10:08:06 PM
My advice is to sell it and get one that already has a 5 speed. This isn't to say it can't be done, but rather it's a lot of extra work that you wouldn't have to do. There are only so many 2nd gen 4Runners around so leave that one for someone who actually wants an auto and build one starting with a manual version. :twocents:
doylejones
doylejones
doylejones
doylejones
doylejones
Have you checked any of your local wrecking yards? Do you need front and rear? If front then look for 1979-1985 4WD models, 1984 & 1985 being the best of the bunch. If rear and if you are going to run leafs, then look for 1986-1995/(96 4Runner), non ABS axles. Another excellent option is 1995-2004 Tacoma rear axles which are 60" wide instead of your stock 58.5" wide axle. This will help keep your glass away from trees. Your 4Runner has coil rear suspension so if you're looking for a direct replacement then you'll need to find another 1990-96 4Runner rear axle.
doylejones
X-Toy Driver
Quote from: BigMike on October 21, 2013, 04:32:51 PM
Big Mike,
How are you notified when you've passed the initiation period and can post to the CLASSIFIEDS Forum?
--Josh Rosado, X-TOY Driver
arickvan
Quote from: X-Toy Driver on June 06, 2019, 02:36:23 PM
Big Mike,
I'll just leave this here  :heavy:
"Attention all new members! :attention:
In order to use the Classified section of our forum, you must advance to the 2nd member group level.
All new members fall into the "Dusty Trails" member group. Anyone who has less than 12 posts is a member of the Dusty Trails group.
Therefore you must accumulate 12 posts or more if you wish to post in this section.
We encourage you to head over to the New Member Check-In! forum and create a new thread to get started!
Also, please note that posts in the Chit Chat Camp are not counted."
