Author Topic: Fuse Identification Help  (Read 1879 times)
jssgbsn
  • Turtle Points: 440
  • Member since Sep '13
« on: Oct 10, 2013, 02:59:12 PM »
I was checking all my fuses and I found a single 10A fuse that was blown.
It is located Top Row, Center Column in the fuse cluster under the drivers dash.
I have an FSM but i cannot find a fuse cluster layout anywhere in it to tell me which fuse is for what.
If anybody has a fuse layout/diagram or could point me to one that would be awesome.
Also, if you happen to know what it is for and the most propbably reason for the blow that would be great too.
Attaching a photobucket link just in case the pic doesn't upload.
http://i977.photobucket.com/albums/ae251/jssgbsn1/Under%20Dash%20Fuse%20Box/IMG_0558_zps0cd6a386.jpg
If I don't ask the stupid question, who will?
85 Runner, 22RE, AEM 'warm intake', TRD Cam, LC Headers, Dual Case, 5.29's, ARB Front Locker, Detroit Rear Locker, 35's, V6 Brakes, ARP Studs, Marlin Arms/Caps/Hy-Steer, Winch, Armor, Can-Back Top....and...
...more Gremlins than Gizmo the Mogwai was responsible for.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: Fuse Identification Help
« Reply #1 on: Oct 10, 2013, 03:08:46 PM »
Where's the fuse box cover?
It shows what each fuse is for.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
jssgbsn [OP]
« Reply #2 on: Oct 10, 2013, 03:33:53 PM »
Wasn't sure if they put a sticker on the covers.
Unfortunately when I bought the 4runner it wasn't included.  They just sit exposed.  Im guessing I could snag a cover from any Gen 1 4runner in a junkyard if I have too.
jssgbsn [OP]
« Reply #3 on: Oct 10, 2013, 03:37:43 PM »
But I did just find this pic on-line.  I'm hoping it is for the '85.
I don't use the cig lighter, but Im guessing it's that.
jssgbsn [OP]
« Reply #4 on: Oct 10, 2013, 03:40:17 PM »
Actually now that I look, that cant be the correct cover.  The pattern is different.  And/or i got incorrect fuses installed.
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
« Reply #5 on: Oct 10, 2013, 03:55:51 PM »
its your cig circuit, i only use mine for charging phones/maglight and my inverter
Cheesemaker
  • Turtle Points: 1346
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #6 on: Oct 10, 2013, 09:08:58 PM »
I have several low wattage items taped into my cig circuit.  Its a great source to draw from, especially when relays are used on the other end.   :yesnod:
jssgbsn [OP]
« Reply #7 on: Oct 11, 2013, 11:09:53 AM »
I haven't checked (been busy with carpet glue removal) after putting a new fuse back in but...
I noticed the lamp indicator was on out my ARB Front Air Locker Compressor Switch.  It was already installed when I purchased the truck so I am guessing it is tied into the same circuit.
Right now, I'm just overwhelmed by the carpet glue and how to adapt this truck to a tropical climate to avoid water/humidity created problems before they start.
Moved from Denver to Pensacola.
Thanks for the advice. :thumbs: :thumbs: :thumbs:
Cheesemaker
  • Male Posts: 4,525
« Reply #8 on: Oct 11, 2013, 12:04:31 PM »
In your climate, I'd do a frame off preservation.
Sand down frame and paint with POR-15.  And I'd rubber coat or POR-15 the under side of the body.  And rubber line the interior.
My environment is mostly wet, and my cab is starting to rust out around the windshield!!  :rivers:  And it seems water likes to seep in from almost every spot imaginable.  I wish I lived in a drier climate.  Oh well, if the body rusts off, then buggy time it is, with rain gear and goggles.   :cheese:
Last post Jan 25, 2003, 11:33:10 AM
by drybone
Last post Jan 24, 2008, 06:01:01 PM
by Bs85
Last post Jan 08, 2009, 08:26:49 PM
by Richmondo
Last post Dec 07, 2009, 09:58:36 PM
by Cheesemaker
Last post Feb 01, 2010, 01:48:38 PM
by CJDavis
