82 toy cheap to sell really fast!!!!!!
Started by builttoabuse, October 07, 2013, 06:26:59 PM
builttoabuse
http://orangecounty.craigslist.org/cto/4116247955.html
Built and dirt cheap
Dana point socal
$3500
toy obsessed!
84toyota4x4sr5
83pete
I can't load craigslist at work, can you cut and paste info?  I'm in LA county and interested.
Thanks
1985CRAWLER
seems like a good deal to someone who wants a really built rig,!
goodluck with the sale!
havik
got another 85 runner. build coming soon!!
builttoabuse
Quote from: 83pete on October 24, 2013, 10:37:20 AMyes sir!
Thanks
Thanks
toy obsessed!
builttoabuse
Quote from: 83pete on October 24, 2013, 10:37:20 AM82 Toyota pick up
-22r with off-road Weber Carb brand new
new plugs wires oil and filter
Duals with Marlin adapter. And 4:70s
New w56c hd. From Mc
New clutch 1600 ftp clutch and clutch bolts
New slave
New flywheeNew exhaust from headers back
Aftermarket headers
Flat bellied trans has been pushed up and back sence Ne. Trans is longer
Tranny tunnel has been redone
New tg crossmember
Optima battery
shock hoops installed up front
Ifs steering box
82 axle with diff armor marlen and truss tg
axle gear oil new
new boom proof motor mounts and tranny mounts
detroit hp 529s up front with mc triple drilled flange
lincon locked with 529s out back
ifs width rear axle with axle armor marlen
new single brake line from cp that splits to to rear brake lines
gas tank has been moved up
front and rear axle seals have been done and front axle has full rebuild
after market gauges
head was rebuild about a guestemnt around 2k ago
aftermarket steering wheel
no ac or heat
35s with front about 30% tread
Crossover steering
Steal braided lines all around and new brak line on rear axle new ppv for rear brakes
Bilsteins in front none in rear
Suspension. Seats black
New spring hanger in front
beds been shortened alot
front blinkers have been joined with corner lights
4 and a half inch shackles
Sits low it's not like most giant lifted Toyota's
chevy 63s in rear
Apr studs in top of the knuckle
ap springs up front
front axle moved forward
Front square drive shaft
Rear Dom and balanced drive shaft
led bulb for tail lights
been flopped over
truck is build for performance
Stereo. But no speakers
No Smog stuff
Clean title
New axle perches welded on in rear for better pinion angle
tags up to date
Runs good
got the Toyota tick they all got its a bit louder but strong!
IT comes with spare tire spare wheel high Jack lift and other extra parts
Sure there's more I for got!
serious people only
Cash only no checks emails or texts
call only (nine four 9)-three95-five-four12
Your gain my loss $3500priced to sell fast!
Thanks
toy obsessed!
builttoabuse
Quote from: 1985CRAWLER on October 24, 2013, 09:15:39 PMthanks sir
toy obsessed!
builttoabuse
Quote from: havik on October 25, 2013, 01:54:06 PMoff the top of my headshot rear axle with brake assembly spare wheel spare tire high Jack lift I forget what else I'm at work
do ya mind listing the spares?
toy obsessed!
builttoabuse
toy obsessed!
