Steering shaft
Started by Snow39, October 07, 2013, 09:40:18 AM
Snow39
How often should I right the bolt or should I just weld the shaft tight
Crunchy Taco
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
Crunchy Taco
That is if your talkin about the rag joint bolts or the u joint clamp bolts
