Project Hippie Killer V2.0: Mean Green Weenie
Started by kdub0013, September 17, 2013, 09:58:34 AM
kdub0013
Well got the crawl box and adapter together. Had to order a shift spring and bolt for the detent ball so I can install the shifter. Plan is install the crawl box section to the tranny and then the atlas last so I can see how much I need to clock it.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
kdub0013
Got the atlas in today and filled. Got the levers adjusted and everything clears. Had to change my front drive line to my spare square front to ditch the cv shaft. I'll have to get that one reworked. Started a simple frame for the center console and need to do the seat mounts. Rubicon trip coming up in a few weeks so I need to get cracking.
kdub0013
Think this is enough slip on the rear? This is where the driveline sits bolted up flange to flange. I know they don't compress in too much.
Dingman.
We usually set them up at 1.5" of compression at ride height
kdub0013
Framed the floor in and started the crossmember mount out of 3/8 flat bar that I will have to notch bend and weld to tuck everything up. I'll throw a few gussets on it as well.
HogCanyonHopper
kdub0013
Thanks dude.
No progress since we were working on the 92 but list before memorial day weekend is as follows
Shorten rear drive line
Build crossmember
Sheet metal tunnel
Front bump stops
Torque everything
That's it for now I am ordering a spartan for the front along with all the Yukon chromo stuff and flanges for the front and a grizzly for the 14 bolt this week from wfo. If I have time I will get the stuff installed in the front at least. Unless some wants to come over and play mechanic while I'm at work lol ill pay!
kdub0013
Got my yukon inners. I'll have the rest of it next week.
kdub0013
Crossmember is in just need to build off of it and add some protection for the atlas.
kdub0013
Well it was a pita but I pulled the atlas redid the studs and bolted it back in and clocked down a little.  Driveline angle was much nicer and I am still higher than my toy case was.
