95' 2wd (4wd project)
Started by AaronB, August 22, 2013, 10:45:51 AM
AaronB
1995 2wd Toyota running unmodified truck
Got the pink from the original owner finally. Bad news is it has $750 in back fees. So Ill knock the total price down 1K.
was originally a California truck but moved to Utah where the PO changed the motor for whatever reason. I have the original motor (in pieces).
in the process of collecting parts to convert, i have a bunch of parts but not everything to complete.
front axle has longfield 30 splines complete with hub gear
v6 third with 4.88 and detroit
needs another knuckle
2 rear axles
one is complete stock from an 83'
other is stripped and started conversion for disc brakes
v6 4.88 third with spool
W56 tranny with dual cases 2.28 front Marlin 4.70 rear
spare 22re
axle rebuild kits
leaf springs
I will not seperate anything!
Located in Tehachapi
$4000 or trade for motorcycle
AaronB
pics
AaronB
more
AaronB
more
AaronB
more
AaronB
more
AaronB
more
floorrunner
#7
Helping u keep it realistic is all.... :beer:
87 4runner, 97 3RZ, dual ultimates, 5.29's air over elocker & arb, true longs R.I.P., York belt driven onboard air and a/c.
AaronB
This isn't Pirate! Be a troll over there.
AaronB
If I register and smog the truck I could easily get 3500 to 4k just for it. Then price up everything else! I could part it out and make the same price. But I'm in no hurry and don't need to.
AaronB
knocked it down a thousand for back fees, asking $4000.
AaronB
will trade for a full squish MTB
Matty
Aaron! What's up man? You still got this thing?
THEMAN
If you decide to part out I want dibs on the front axle.
AaronB
yotatough
AaronB
#16
4000
AaronB
AaronB
AaronB
AaronB
Spare Motor is gone, but still have everything else. $3000
