This may be the stupidest question i have asked......
Started by jeradx10, July 31, 2013, 06:17:41 PM
jeradx10
all this talk about leaf spring and shopping around, front spring/ rear springs    is there a difference between front and rear or are they all the same.... iv read on some forums that the fronts are narrower than the back on some years... please help me clarify thanks!!!!
They are different in length, capacity and how they are set up. Rears are longer than fronts, the fronts are designed to take the weight of the engine above them and the rears are designed with varied load weights. They do swap rears to the front though with modifications to the springs and mounting points but the fronts are not.
jeradx10
Okay thanks, I'm going with the trail gear 3link in the front but my buddy had a set of 5" all pro springs and I was gonna put those in the rear but they are the springs off the front of his truck because he also has the trail gear 3link that's why he has them layin around...
Wainiha
Could you pull a leaf or two from the pack to make it work?
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
King resi C/O
and Total Chaos UCAs
jeradx10
That's what I'm wondering, has anyone around made it work before and would it have good flex?!?!?
