Author Topic: Alignment ????  (Read 1478 times)
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • Member since Sep '07
  • CAN'T POLISH A TURD!
Alignment ????
« on: Jul 09, 2013, 03:49:30 PM »
Does anyone know anywhere in Fresno that can align solid axles with big tires right ?
Cheesemaker
  • Turtle Points: 1346
  • Male Posts: 4,525
  • Member since Sep '04
Re: Alignment ????
« Reply #1 on: Jul 09, 2013, 05:42:20 PM »
Alignments are easy on a straight axle.  Just need some clamps, angle iron (at least 3' in length), and a tape measure.  But periodically, you should hit a alignment shop to get the front in line with the rear tires.  I've seen alot of rigs crab walking down the road, because the rear is out of whack.
blumagoo
  • Turtle Points: 2
  • Member since Jul '10
Re: Alignment ????
« Reply #2 on: Jul 10, 2013, 09:12:42 AM »
Solid axle alignments are do it your self affairs. You can check the toe with a tape measure and get the caster with a level and a protractor. As far as the crab walk thing just have someone follow you to see what it's doing and adjust accordingly
sparkys83yota
  • Turtle Points: 6
  • Male Posts: 320
  • Member since Jul '09
Re: Alignment ????
« Reply #3 on: Jul 10, 2013, 11:31:22 AM »
I thought that the crab walking effect was a result of not setting up your rear spring hangers correctly. I didnt know it could work itself out if wack.
83 shorbed pickup. 22 re swap. Dual ultimates, l52hd tranny, 5 " marlin trailflex lift. Yukon 529. Grizzly in rear zip locker front. And a bunch of other stuff....
Cheesemaker
  • Male Posts: 4,525
Re: Alignment ????
« Reply #4 on: Jul 10, 2013, 03:07:37 PM »
Working at a tire shop years ago, I've seen many of rigs with OEM springs in the rear be out of whack.  Ford was notorious for the front ends being out of alignment off the show room floor.  But if your off by a little bit when installing your leaf spring hangars, it will cause the rear to crab.  Or if one leaf spring is flatter than the other, it will offset the axle.  Or bushing will wear out too.
Last post Nov 14, 2004, 02:31:12 PM
by Duffil
Last post Mar 08, 2007, 07:52:50 PM
by 79coyotefrg
Last post Nov 11, 2013, 11:16:06 AM
by Duodenum
Last post Aug 14, 2014, 01:32:56 PM
by jssgbsn
Last post Mar 12, 2018, 07:45:38 AM
by fasterspider
