Author Topic: Crankshaft pulley bolt  (Read 1578 times)
Kyle20r4spd
  • Turtle Points: 3
  • Male Posts: 82
  • Member since Mar '13
  • Gotta Love A Yoter!!!
« on: Jul 07, 2013, 03:19:35 PM »
Is the bolt on the crankshaft pulley left handed thread or normal? I can't seem to get it to spin either way. Am I doing something wrong. it is the main bolt right in the center of the pulley. I have the motor stopped from turning with a crow bar on the flywheel bolts but the bolt is not budging please help :help: this is on a 20r. I don't want to shear it off either.
« Last Edit: Jul 07, 2013, 03:53:22 PM by Kyle20r4spd »
Just put er' to the wood and it'll make it!!! -Dylan W.
Isn't ketchup technically a tomato smoothie???
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Crankshaft pulley bolt
« Reply #1 on: Jul 07, 2013, 06:39:33 PM »
Right hand.
Some people use a long breaker bar, rest it on the frame and bump the starter to loosen it. Make sure to pull the coil wire if you use this method.
Another person I know could not get his loose no matter what he did; he ended up slicing pieces out of the flange on the bolt. Then it spun right off.
I had to do the same thing to one of the cam bolts on my 3.0.
Kyle20r4spd [OP]
  • Turtle Points: 3
  • Male Posts: 82
« Reply #2 on: Jul 07, 2013, 09:27:22 PM »
It isn't to important, I was just going to replace the timing chain cover gasket I thought it was the leak but ended up being the power steering pump. So I just re torqued all the bolts and am just going to run it after I get the new pump. I would have used the starter method, but here is no tranny and no flywheel so therefore no starter :thumbdown: Thanks for the reply though. If it has a leaky gasket oh well, I am having a 20r being built by shark racing engines right now so a little oil is not a big deal. :thumbs: http://www.sharkracingengines.com/about%20us.htm They specialize in sprint car engines but will build pretty much anything. Its going to be sick :booya:
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #3 on: Jul 08, 2013, 01:52:27 AM »
Impact wrench......
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
« Reply #4 on: Jul 08, 2013, 08:11:46 AM »
I have had great success heating the end of the bolt up with a propane torch.  Get it nice and hot, maybe 10 minutes with the torch.  It's about right when you can burn your finger bad enough on it that it sizzles and quits hurting quickely because it killed the nerve endings in your fingertip. Then use a big breaker bar or cheater pipe on your 1/2 inch ratchet and you should be able to break it loose.
I don't think the finger test is really necessary but that seems to be about the right temperature.
– Steve McQueen
Vang530
  • Member since May '12
« Reply #5 on: Jul 14, 2013, 12:31:15 AM »
i use the starter method to loosen it, if its off the truck already and an impact won't work, i use a chain wrench (hasn't failed me yet after 5 times)
Oroville, CA
Last post Mar 16, 2006, 05:07:32 PM
by Hyena
Last post Mar 09, 2007, 07:47:53 PM
by Tice
Last post Sep 23, 2017, 08:04:18 PM
by jimbo74
Last post Oct 16, 2013, 05:14:02 PM
by Moit88RNR
Last post Jun 04, 2016, 11:04:21 PM
by jimbo74
