new to crawlin, but wanna learn
Started by amm9130, April 13, 2013, 05:20:33 PM
amm9130
I'm new to crawlin and I want to weld my spider gears in the rear end. Ive never done this before but i have a 3rd member to practice on. I need step by step directions and some pics so I kno what I'm doin. I appreciate any help i get. Thanks in advance.
1994 Pickup DLX 22re 5speed 7 in lift 37 in iroks
amm9130
How does a locker or welding the rear end effect the steering in everyday driving. I wanna add the extra traction but dont wanna make it where my wife cant drive it.
builttoabuse
Quote from: amm9130 on April 16, 2013, 06:13:00 PM
everyone has their own opinion. I run locker in front and welded in the rear  there's pros and cons about everything. I daiily drive my truck on the street I love having it welded offroad but it sometimes gets annoying but its not bad my rear tires don't get to worn out fast
toy obsessed!
amm9130
Ok. I'm gonna weld mine for to long. If I end up not liking it I'll get another rear end, but i don't think that'll happen
builttoabuse
Do it man you'll never know if you like it inless you try it! Get an old axle shaft cut it so it will fit in to the spider gears and weld spider gers and axle piece togther :greengrin:
toy obsessed!
amm9130
 :thumbs: that's right. I've got a piece of steel cut to go in the spider gears
nisota
Before welding spider gears please read this if you haven't already.  http://www.brewracingframes.com/id75.htm Welcome to crawling  :thumbs:
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
amm9130
Thank you very much for that information. I had not seen that before. Very helpful
builttoabuse
Quote from: nisota on April 20, 2013, 02:12:11 PM
good man!
toy obsessed!
builttoabuse
Quote from: amm9130 on April 20, 2013, 02:56:46 PM
That makes two!
toy obsessed!
Nation
amm9130
Not yet, still tryin to track down a friend with a welder I could borrow. Any certain size wire or amp do the job better?
MRHilux87
Weld it.  Wears tires a little faster but not so much that its worth spending money on a locker for the rear.  If the person welding has experience and you use some plate steel between the gears you can get away with a 110 volt welder.  If you want to be safe or don't have as much experience a 220 volt welder can get more penetration with less skill.
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
mrghost
Quote from: MRHilux87 on May 19, 2013, 12:19:19 PM
with the 110 volt welder weld the gears together a bit before you weld the plate in.
#FUNMATE#
Some have welded plate between the spider gears which seems to be the strongest, but remember to not overheat things. Give it time to cool between welds so warping does not occur. There are several threads on the subject here, just search for them.
88sasturbotoy
Weld it I hate lockers I hate how they click in and out making bad clanging noises I welded mine front and rear love it nothing is better than.all 4 digging when you want em to....if I was you I'd find a buddy that has a good stick welder mig is kind of picky but a stick will burn thru anything it does care greasy or dirty it welds .  .
88 xtra cab pickup solid axle swapped 5spd swapped 4.7 swap turbo 15psi swapped = rowdy
