Big welding wire spools, little welders
Started by junya92toy, April 08, 2013, 07:57:16 PM
junya92toy
So if you look around, sometimes you can find great deals on bulk products. I was looking online and found a brand of wire the local welding supply store has. Anchor brand, I called them up, 035 hard wire, 33 pound spool 82 bucks. I found the same but in a 44 pound spool for 74, free shipping.
So I decided to build a external wire holder for my miller 211.
I had everything but the bolt, washers and nut laying around.
Basic of the holder are, I used some plate for the base ,angle for the column, 2 inch round tube for the spindle misc flat bar and a small bolt for the pin, to keep the spool "attached" to the 2 inch tube and a spring. You want to do a slight angle to keep the spool from coming off.
The end and the spring used to put pressure on the spindle so it can not unwrap
Getting the wire into the welder, simple drill a hole, and you can see i used a gun liner I had laying around so it will feed nicely past the hole and not chafe.
I cut it just long enough to go into where the drive roll is.
It looks like I have 2 wires going into the drive roll, I dont, I just did a mock up of the second liner.
Next I made a small block to hold the liner in place, 2 magnets to hold it to the case, and a set screw
And thats it. Another perk to this setup is, you and keep a smaller roll of wire in the welder as well. I have .035 dualshield for when I need to do heavy welding. It is a gas shield flux core wire but it used the same polarity as hard wire.
IronClad
Nice! you did the hard work for me :D we talked about doing somthing like this a while ago, let me know how it works long term wise since i have 2 large spools of .035 sitting on a shelf for when i burn through this one.
Annihilation  Fabrication
Do you need a Hammer?
junya92toy
I just finished it up tonight, I ran some beads and it welds like normal. I dont ever see anything that could be a issue with it.
IronClad
right on. i even have an old liner that is torn down by where it goes into the welder. might be able to salvage it to do the same thing
Moit88RNR
Nice work. I'll be doing this in the future  :beerchug:
Sparkplug
Nice!  10 lbs is enough for me but the price savings is definitely something for me to consider.
Hezzy
care to give out your website for where you found the wire?
hunting+ yotas+ daughters + wife= no $
junya92toy
pumkin toy
good job man, I did this to my Hobart 187 about a year ago.  I have never had a problem with it.  I save tons of money by using the 44 lb spools.  I buy mine through linweld here in Rapid City SD.  I use Viking brand wire. a 44lb spool of .035 hard wire only cost me 50 bucks.  Compared to spending 27 on a 10lb spool.  That's a savings of about 68 bucks every time I use up a 44 pounder!  Its worth it for sure to do this mod if you use your welder all the time.
97 4runner Limited
junya92toy
Yes its a huge savings thats for sure. Getting free wire in a way haha. Only thing I would say is, I will be getting a wire cleaner for it since its exposed now. But its cheap to get them
junya92toy
Been running some wire with this setup, here is a vertical up. Works great so far
HogCanyonHopper
 :thumbsup: nice job Jerry. that would work real sweet with my Hobart 140
Hezzy
Thanks!! this is an awesome project I hope to scratch off my list someday soon.
MRHilux87
Never thought of that but I just put my 3rd or 4th 10lb spool on this year and it sucks.  Did you build a rack on your welding cart for the bigger spool or do you just have a really long stinger?
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
junya92toy
The holder for the big spool is directly behind the welder or it wouldnt work
