AC Compressor for OBA
Started by nastyneight, April 07, 2013, 06:13:47 PM
nastyneight
Im converting my AC Compressor to OBA. Most people do the Oil in the air line then a seperator after. I'v heard of a few people taking there compressors apart and redoing them so they geases them and seal them and no need for the oil (i have two compressors so i dont want to use a York) I ve searched alot of forums and i cant find anything on this. Anyone know about this being possible or not.
OOPS
I have never heard of doing that, but anything is possible. I know that the Sanden rotary compressor has oil in the crankcase but uou still have to run a drip system with them, learned that the hard way!!!
John Doe
Quote from: nastyneight on April 07, 2013, 06:13:47 PM
I recently read an article about this in a 4x4 mag. I am going to try the same thing when I am done with my 3.4 swap.
OOPS
What magazine, I would like to read it.
Alberta 7.3
John Doe
Quote from: OOPS on April 09, 2013, 07:25:38 AM
4x4 garage, spring 2013 issue. Picture of a green tj jeep descending a hill in Moab on the cover.
OOPS
Quote from: Alberta 7.3 on April 09, 2013, 08:25:56 PM
http://www.grungle.com/endlessair.html
A good article on modifying the Sanden compressor.
If you can get a hold of a Sanden and I think the numbers are SD07 they have real good output. I had one and burned it up, it has seven pistons. When I bought my 90 it had an aftermarket AC and that was the pump that was on it.
