Winters AW340 Shifter-upgraded
Started by R.DesJardin, April 06, 2013, 06:27:26 PM
R.DesJardin
Thought I'd try one of these Maverick Performance/Winters A340 Shifters out for now. I added a switch kit that can control the trans, 1-4 electrically and with the floor shifter at the same time hydraulically, so engine braking with each gear when downshifting. On this one I modified the stock shift plate so I could get easy fwd to Reverse shifting but still have good stops in 1st, 2nd and 3rd which are the most used gear when wheelin' I also machined out a "billet" mounting plate that I can mount On-Off switches in on the left side plate. Now to rebuild the center console for it.
R.DesJardin
mudmaster
Time to go wheelin!
Doable
How did the shifter  work out? I really don't like how the factory shifter is so lose.
Nothing puts a smlie on my face like the green glow of 4x4 on the dash !
BSLCA.com
R.DesJardin
Usually the factory shifter is loose because the pivot bushings need replaced. And I haven't got this new one installed yet, I'm rebuilding/building up my 2RZ right now head should be done next week, then I have to set up the LCE cams and finishing putting the motor together, then install the shift improver kit for the A340 and then the shifter so I can run the crap out of it all.
R.DesJardin
Ritchie
Quote from: R.DesJardin on May 03, 2013, 03:53:24 PM
I like that shifter.
Also,
I have seen the link your build and cannot find it... have a link?
Later
'03 Step side Pre-runner, F/R 4WU 3 linked, F/R Diamond axles, F/R ARB's w/5.29's, F/R Fox 12" CO's, ShrockWorks front bumper, self made rear bumper, WARN M8000S w/ remote, 4.7 Inchworm Lefty, MC sliders that hold air & a bunch of other stuff.
R.DesJardin
Search R.DesJardin, on here or most anywhere, I have the swap and duals with the auto threads.
Quote from: Ritchie on June 21, 2013, 04:00:11 AM
Also,
Later
R.DesJardin
