Author Topic: Just want to be sure SR5 Cluster install  (Read 1533 times)
firealj
  • Male Posts: 113
  • Member since May '12
« on: Mar 10, 2013, 01:40:27 PM »
Can anyone help me. Im installing mine now. i have a 1988 4runner Non SR5 and i have a new oil pressure unit for my new SR5 cluster ( the large one) and need some step by step install help. searched here on marlin didnt find anything specific to my needs(or link me). also have two questions 1) when i pull the oil unit off will oil gush out? or just a little. 2) theres a white wire with a black line on the wire can i just re-use this wire? is there anything else i need to do for my model and year. (dont know yr of cluster but it is a sr5 one with tach. thanks
John Doe
  • Turtle Points: 469
  • Male Posts: 1,587
  • Member since Jun '05
    • Bored In Iraq.
Re: Just want to be sure SR5 Cluster install
« Reply #1 on: Mar 10, 2013, 02:01:57 PM »
re-use the wire, and there will be a little oil, but not much. It is a quick easy swap.
firealj [OP]
  • Male Posts: 113
« Reply #2 on: Mar 10, 2013, 02:31:47 PM »
ok thank you. SO is the sensor directly below the oil filter and has a white wire with black stripe,. Or is it the sensor to the left  of the oil filter with a black wire?
Dirt Mover
  • Turtle Points: 186
  • Male Posts: 355
  • Member since Sep '03
  • Chrome won't get you home
« Reply #3 on: Mar 10, 2013, 08:56:33 PM »
Just swapped an SR5 into mine this weekend, but haven't got a new sending unit yet so it's unplugged. My wire goes under the filter like yours and has a rubber boot.
On mine everything is working but the water temp gauge. I have like 7.5 volts at the sending unit, but something isn't working right.
John Doe
  • Male Posts: 1,587
    • Bored In Iraq.
« Reply #4 on: Mar 10, 2013, 10:17:59 PM »
Sadly I do not remember and I recently pulled my 22re and all of its associated wiring.
firealj [OP]
  • Male Posts: 113
« Reply #5 on: Mar 11, 2013, 10:16:17 AM »
so i just installed mine everthing works but the oil pressure. i have a tab on the oil sensor to connect the wire and doesnt move but when i connect the wire to the nipple looking tab on the end i get the needle to move "slightly" do i need to cut the wire and splice it to both ends? i saw some weird things done on other sites and google images with this connection. everything seems to be ok but that.
John Doe
  • Male Posts: 1,587
    • Bored In Iraq.
« Reply #6 on: Mar 21, 2013, 10:34:31 PM »
All I had to do was change the oil pressure sending unit and plug the old plug into the new 1.
firealj [OP]
  • Male Posts: 113
« Reply #7 on: Mar 22, 2013, 06:40:40 PM »
mine hops every once and awhile
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« Reply #8 on: Apr 08, 2013, 07:51:39 PM »
best thing to do for a more true reading is to get a small dual aftermarket sensor they sel a oil and temp gauge for cheap pick one up and save yourself the worry  EVERYONE KNOWS that the stock gauges arnt true.  I have used a stock one in the dash and a aftermarket one side by side because my stock one said I have ZERO oil presure but my aftermarket one said I have GREAT PRESURE
[img]http://bo
Last post Aug 15, 2008, 11:01:07 PM
by GJToyotabug
Last post Apr 06, 2005, 07:23:47 PM
by YOguyDa
Last post Feb 17, 2010, 09:47:23 PM
by fade
Last post May 31, 2010, 05:53:06 PM
by OOPS
Last post Nov 08, 2010, 07:08:58 AM
by 22hilux
