Author Topic: misterious puddling on passenger floor board...  (Read 2264 times)
82.1st.gen
  • Turtle Points: 37
  • Male Posts: 52
  • Member since Jul '08
« on: Mar 05, 2013, 08:12:54 PM »
Checked all drain plugs cleaned valance and everything i could think of  windshield seal is good checked the sunroof  everything is sealed good and i still get water on the floor board of my truck... any one else have this problem? My truck is  a 92 ex cab
1992 Toyota 4x4 sr5 auto/3.0 swapped to r150f 5 speed and 3.0 swapped for 02 3.4!
toe
  • Turtle Points: -60
  • Male Posts: 1,693
  • Member since Dec '09
Quit scaring the piss out of your passengers............
 :cheese:
Me
T.Rex
  • Male Posts: 164
  • Member since Mar '10
Ac leaking the drain tube for your ac is clogged
T.Rex
  • Male Posts: 164
Evaporator housing tube. Couldn't think of what is was called earlier. Hope it helps
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
assuming not coolant?........... i have a mystery leak on my 91........  only leaks when i rains HARD... i just drain the rubber floor mat every other day... lol
Those are some huge welds!
Tillamook, OR
Prismo
  • Turtle Points: 8461
  • Member since Oct '03
  • Living in the green house
If it is coolant it is the heater core
Coopie
  • Member since Feb '13
My windshield looked like it was sealed fine, but I eventually found the leak to be coming from the top of the windshield. It was just a drop every couple minutes, but it would leave a huge puddle overnight.
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
Its not coolant. Ill check the evap tube i dont think it could be anything from the ac system i tore all that out when i did my 3.4 swap and ill double triple check the windsheild. And like  bleakhorizon it only does it when its pissin down rain.
camhays556
  • Turtle Points: 498
  • Member since Nov '12
mine makes a puddle when it rains hard to. its the windshield seal
DRTYLUVN
  • Turtle Points: -19
  • Member since Oct '11
my uncles 85 runner had the same problem
ended up he was leaking from the antenna hole (where the antenna cable goes thru, out the cab and up the fender)
we sealed the antenna mount at the fender but it was still leaking thru
well it was the same hole that it was coming thru but we noticed that when it rains hard enough the vents on the front top of the cab (where the bottom of the windshield is) would fill up and overflow (Dont know why it wouldnt drain) and the water would come down the antenna cable coming inside into the cab
you couldnt see where it was comin from and it would just puddle
well it came down right next to the ecu on the passenger side, with rubber/plastics removed from that area you can see it flow like a creek lol
we didnt/couldnt fix it, i told him just make sure to remember to pull the drain plug on the floor when it rains
Cheesemaker
  • Turtle Points: 1346
  • Male Posts: 4,525
  • Member since Sep '04
My old Nissan would leak water only when it would rain so hard, that the cowl intake drain would be overwhelmed to the point that the water would pour into the heater intake.
I get some seepage in my 87, and it comes from the rear window gasket, and on the passenger front.  It's not alot, just enough to kinda get you all bent once in a while.  Then I think back to my old El Camino, it was like Niagara falls when it rained from the heater.  And would rain on me from the sunroof.
Last post Jun 19, 2007, 01:51:55 AM
by Snowtoy
Last post Oct 03, 2007, 12:44:38 PM
by hot_karl
Last post Oct 24, 2009, 04:13:46 PM
by illinoisyotadriver
Last post Apr 27, 2010, 07:58:26 PM
by hiluxtrux
Last post Apr 17, 2010, 08:34:51 AM
by Redbeard1
